Cannot get NLP 3.1 to work with Lightroom Classic 2026
Hi there, I’m hoping someone can help me with this. For a backstory, I typically manually invert DNG files in photoshop to a finished photo. However, I thought I’d give NLP a try for more convenience. I scan using Vuescan to Raw DNG 48bit. I bought NLP and downloaded it to lightroom classic:
  1. The first attempt I ran the DNG tool in the options (I cant remember the name) under plugin extras with one dng selected. then I opened NLP and converted. it looked fine. I clicked on the second dng and did the same, but it said profile missing. I clicked convert and it acted like it was converting and opened the adjustments dialogue but it didn’t actually convert anything.
  2. after troubleshooting and looking through these forums I reinstalled everything (including Lightroom and NLP) and selected all of the DNGs in the roll, ran the DNG tool in the plugin extras menu. then all of them said profile missing.
Now I cant get anything to work at all. The DNGs were 48 bit RAW from Vuescan using my Primefilm PF3610AFL. I would like to get this to work. Thank you for any help!
Welcome to the forum @nickm2363
There is no profile indeed for this scanner in NLP. Supported PrimeFilm profiles are these:
Negative Lab - PIE PrimeFilm 120 Pro 2.3.dcp
Negative Lab - PIE PrimeFilm 7200 2.3.dcp
Negative Lab - PIE PrimeFilm XA 2.3.dcp
Negative Lab - PIE PrimeFilm XA v2.1.dcp
Negative Lab - PIE PrimeFilm XA v2.dcp
Negative Lab - PIE PrimeFilm XAs 2.3.dcp
Negative Lab - PIE PrimeFilm XAs FS 2.3.dcp
Negative Lab - PIE PrimeFilm XE 2.3.dcp
Negative Lab - PIE PrimeFilm XE v2.1.dcp
Negative Lab - PIE PrimeFilm XE v2.dcp
You can ask @nate to create a profile via private message: click on his avatar and then, on the blue envelope.
Alternatively, you can try to find out which profile was used when you converted your first image and then try to use that profile for a while. Look at metadata in Lightroom or exported files. Can’t say where your chances are best though.
