A lightroom clone is out, “lightcraft”.
I am currently using this over lightroom and for the moment it’s the same thing… but free…
Do anyone know (or is capable in AI coding) to port NLP to Lightcraft ?
Thanks a lot !
I am probably about to make this and make it open source. I’m kinda busy rn but should have it done within 3 months. I would love an official port but ngl I doubt it’s ever happening.
Follow my GitHub, FugLong, and I’ll try to remember to post here too
Wild to post this on the official forum.
If Lightcraft a clone of Lightroom, shouldn’t the plugin just work?
wild to post on the official forum essentially asking to pirate NLP. but if you really dont want to use Lr and dont mind using vibecoded projects just use Negpy.
FugLong
October 17, 2026, 11:21pm
5
Okay peeps, it was actually easier than I thought it would be. Shout out to the LLMs taking my job lol .
IMO it’s not wild to post on the official forum. LightCraft was made without adobe code and my new fork/PR adds “Negative Craft”, which was made without NLP code or screenshots or anything.
I have a PR up like I said but there are over 400 right now so who knows if mine will get in lol.
If you want to try it before it makes it into prod just follow these steps:
You need Rust installed (https://rustup.rs ). Then:
git clone -b film/negative-craft https://github.com/FugLong/lightcraft.git
cd lightcraft
cargo run --release -p lightcraft -- --memory
--memory opens a throwaway library, so nothing is written to your real photos or your normal LightCraft library. The first build takes a while.
Then,
Open a photo and press E for Edit.
Choose Window ▸ Edit Sections ▸ Negative Craft.
The section appears above Light.
Choose Color Neg or B&W, then click Convert.
The scan needs a strip of blank film around the picture. That border is what the conversion reads.
My PR if anyone later down the line is curious if it made it in (also has example pics in comments):
main ← FugLong:film/negative-craft
opened 11:09PM - 17 Oct 26 UTC
## What this is
Negative Craft turns a scan of a film negative into a normal ph… oto. You photograph or scan the negative, and LightCraft prints the picture. It works for color negatives and black-and-white negatives.
It is meant to do the job that Negative Lab Pro does in Lightroom. Negative Lab Pro was not opened, copied, measured, or studied while this was built. The conversion is LightCraft's own.
## How to turn it on
Negative Craft stays hidden until you ask for it.
1. Open a photo and press `E` for **Edit**.
2. Choose **Window ▸ Edit Sections ▸ Negative Craft**.
3. The section appears above **Light**, and it stays there on later photos. The menu item stays checked.
4. Choose **Color Neg** or **B&W**, then click **Convert**.
To put it away, right-click the **Negative Craft** header and choose **Hide Negative Craft**. A photo you have already converted still shows the section, so you can keep working on that print.
## Getting a good print
Leave a strip of the blank film around the picture in the scan. **Convert** reads that border and builds the photo from it. A pale border is fine. A border that is pure white is clipped, and the orange film base is no longer in the file.
Lock the camera's white balance for the whole roll (Daylight works) and use the same exposure, aperture, and ISO. A raw file keeps the film color more faithfully than a JPEG of the same negative.
After **Convert**, leave **Contrast** at **1**, then set **Exposure** and **Blacks**. The full scanning and printing steps are in `docs/user/guides/convert-a-negative.md`.
## What it does not do
- It cannot invent the blank film if the scan is cropped tight to the picture. **Match roll** does not fill that in. Each frame needs its own border.
- It does not ship a measured profile for each film stock. **Color Neg**, **B&W**, and the scan type (**Camera**, **Minilab**, **Flat**) are the choices.
- Slides are already positives, so they are not on this panel.
Incredible work, thanks a lot.
Hey all just wanted to come back and say it was NOT easier than I thought I was just tired and lazy. After actually trying it for a lot of film I wasn’t satisfied. Even after a few weeks of work, me and AI, we can’t touch NLP’s conversion accuracy lol. I just compared with the real deal (NLP) and a real lab scan tonight and damn I’m still off way more than I want to be.
I think over time I can get it closer but right now still ain’t it
FugLong
October 30, 2026, 11:23pm
8
Anyone who is curious about this, I have closed my PR. This goated spaniard has a much better implementation I am going to help test and improve.
main ← smyrgeorge:convert-negative/1-film
opened 08:41PM - 21 Oct 26 UTC
## Summary
Part 1 of 4 of Convert Negative (Photo ▸ Convert Negative, film-nega… tive conversion), split from #2364 as suggested in review. Landing order:
1. **this PR**: `crates/film` (`lightcraft-film`, L1), a library with no caller yet
2. settings and the pipeline stage
3. engine commands
4. Photo menu entry, panel and docs
## What's in it
`lightcraft-film` is the negative-conversion maths, ported from [Film Lab](https://github.com/smyrgeorge/film-lab) (same author, MIT). It's Film Lab's core crate almost unchanged, without the PhotoCraft-only sharpening and JSON parameter scanning:
- **Film model** (`film.rs`): density grows with log exposure; each channel is read relative to the film base, which also removes the orange mask.
- **Levels** (`analysis.rs`): each channel's density range between its black and white points maps onto the same stops of scene brightness.
- **Colour and tone** (`look.rs`, `tone.rs`, `color.rs`): white balance, colour models, toning, tone profiles; `Converter` with an exact path and a table-driven path.
- **Film presets** (`preset.rs`): Standard, Portra 160 / 400, Ektar 100, Gold 200, ColorPlus 200, UltraMax 400, Superia 400, C200, Pro 400H, CineStill 800, Monochrome. Film names are their makers' trademarks and only say which stock a preset takes after.
- **New: whole-scan measurement** (`measure.rs`): the film base, per-channel black and white points and a neutral balance, measured once inside a border. A host stores the result with the photo's settings, so every render converts with the same numbers.
Other changes: `libm` becomes a workspace dependency (pure Rust, already in the lockfile), and `film` is registered as L1 in `xtask/src/layers.rs`.
## Testing
- `cargo clippy --workspace --all-targets -- -D warnings` is clean, and `cargo xtask layers` passes.
- `cargo test -p lightcraft-film`: 37 tests pass. That's Film Lab's suite (round trip of the film model, both encodings, tables against the exact path, hostile parameters) plus measurement tests (a synthetic negative with a border, short buffers, flat images, NaN input).
- The whole series, as one branch, passed the full `cargo xtask ci` (all 8 steps) in #2364.
🤖 Generated with [Claude Code](https://claude.com/claude-code)
## Summary by CodeRabbit
- **New Features**
- Added film-negative conversion with configurable exposure, contrast, tone, color, saturation, white balance, and toning controls.
- Added scan analysis and measurement for automatically determining film base, black points, white points, and color balance.
- Added support for linear and sRGB workflows with reliable color and luminance handling.
- Added 12 film-stock presets, multiple looks, tone profiles, and monochrome output.
- Added accurate table-based conversion for efficient image processing.
- Added safeguards for invalid or extreme inputs, producing stable bounded results.
Snowii
November 15, 2026, 1:19pm
10
Damn man, just wanted to show some appreciation for all the hard work you must have put into this. Looking at the current state of Lightcraft and the fact that you already have some kind of auto-crop functionality, maybe it would be worth submitting that feature as a separate PR?
