I want to ask if there is a possibility in getting more presets? So like Fuji or Agfa Vista, Porta 800 and so on? This would be very nice ![]()
Or does someone already have those presets?
Greetings
Richard
Greetings
Richard
As an ex-lab guy who calibrated and set up high speed, high performance Kodak Bremson HR500 scanners, I can testify to the extreme challenges of creating “film terms” or presets for individual films. Film characteristics vary by:
Film generation, emulsion number, age, processing conditions, brand, speed, type, and (of course) exposure conditions, including light source, under/overexposure, contrast range, etc.
It is certainly possible to create a preset yourself, and save it. That’s what I recommend. If you want the most neutral thing you can get, start with a fresh roll of film. Expose a ColorChecker Chart at 1/3 stop intervals from two stops under to two stops over the meter reading of a gray card, making all exposures in mid-day daylight (open sky with direct sun). Process the film and then camera scan it. Convert the negatives with the latest software version, after freshly calibrating and profiling your monitor with a hardware solution. Make changes to the conversion of each negative, attempting to get the color to match the ColorChecker Chart as closely as possible. Save each result as a preset for the noted exposure level of that frame.
What this will give you is merely a set of starting points for under- and over-exposed and normally exposed film of that current type. It’s better than nothing! It should be better than the defaults, but keep in mind that lighting changes and exposure changes, process changes and emulsion number changes WILL skew the results.
One of the reasons I like digital imaging so much is that the degree of precision controls we have is an order of magnitude easier to deal with than it ever was with film.
Hi and thanks for your input.
You speak of a preset for my digital camera? So conversion of the negative, than matching the converted digital photo to the color checker and make a preset out of it? I thought the presets in NLP are complete different than normal digital camera presets and therefor I asked for some presets from @nate ![]()
I thought making a preset for my digital camera it is the other way around: Doing 2 photographs of the color checker, one with film and same time one with digital. Convert the negative of a color checker photograph, having the shifted colors from film, shifting the digital photograph to the same shifted colors from the negative. The thing is, what is the good or correct conversion of the negative?! So I have the problem that the conversions from my canon scans are sometimes way to dark and the colors are off. With this circumstances I’m not able to convert it properly. I need a real scanner and a calibrated tool chain in order to make a good preset.
I mean, of course it is a thing with the colorreproduction as you said. However, it is good to have a starting point from a guy he is knowing how to deal with many situations and provide a preset for that.
