NLP and Mac OS Golden Gate?
Any idea on timeline for compatibility of Negative Lab Pro and Mac OS Golden Gate? Am bringing in a new machine that ships with Mac OS 27 for running Lightroom Classic, and Negative Lab Pro (3.11) is one of my essential mainstays. At moment it appears I’ll need to keep using a machine with previous OS 26 as I read Adobe apps not certified yet for latest Mac OS. Just wondering what is situation ahead for NLP, which along with LRC is mission critical for me. Thanks any insights!!
Read about an early test here: NLP on Lightroom Classic on macOS "Golden Gate"
If Lightroom Classic is critical, don’t upgrade your OS without thorough testing on a separate volume or Mac. “Never change a working system” - if you depend on it.
Test on your new Mac before flipping the switch.
Today’s news from Lightroom Queen concerning the topic:
macOS: we've had lots ask if Lightroom will run on macOS 27 (Golden Gate). Many have installed this now, and it seems to run fine. However, be aware that Lightroom isn't actually supported on it yet - look out for the new releases at Adobe Max.
See Lightroom and macOS 27 Golden Gate Compatibility | The Lightroom Queen
I run Mac OS 27.0.1, LR classic 15.6 and NLP 3.1.1 and don’t have any issues with LR classic. Intermittantly with NLP a ‘task completed’ window is persistant after starting NLP i.e. the task completed window won’t go away. I just move it aside and continue editing with NLP and everything seems to work otherwise as it should. Some one else mentioned this issue in another post. It doesn’t occure each time I open NLP and no idea if it’s a NLP/Lightroom classic issue alone or a combination of the OS/ LR classic and NLP.
I am having this issue also, but not sure if Golden Gate is the issue or the latest LRC update. But this happens at random.
Testing with LrC 15.6 on macOS 27.0 (not 27.0.1) got me the sticky progress bar issue too. Not always and decreasingly often with increasing number of using NLP. After a while, the window disappeared every time as expected.
I suspect LrC 15.6 to cause the issue because I never got it before updating to 15.6.
I recommend to install and back up the most reliable versions of Lightroom Classic 14 - for those who still use it. LrC 16 will come soon and LrC14 downloads will then go away. Older versions of 15 should stay available for another year or so.
Here’s a screenshot of the exact issue in case anyone needs to see it.
