Hi all,
I kinda settled on diffused light as a preferred source, but now this new discussion on lens resolutions made me wonder whether it made sense to take the scanner lens out of my minolta scan multi ii instead of selling it, and more general, what lens (and camera) resolution would be sufficient (for me) and whether what I have is enough. So I started rambling around on the apples and pears comparisons of lines per mm (Units and conversions for resolution) and DPI’s (How to convert pixel size to line pairs per millimeter? | OptoWiki Knowledge Base) and wanted share what I found to see if that made sense.
It seems that consumer films have around 35-50 lp/mm (line pairs per mm) while Kodak introduced at some point higher resolution T-Max at around 100 lp/mm and above (Resolution and MTF curves in film and lenses).
My camera (Nikon Df) has an image resolution of 4928x3280 and a pixel pitch of 7.28 micrometer. What I read is that these pixels are individual R, G, and B, but I assume Nikon does some fancy stuff to retain at least that pixel pitch resolution while doing the color calc. From what I read, 7.28 micrometer would translate to something like 500/(7.28x1.4)= 49 lp/mm for B&W and 500/(7.28x2)= 34 lp/mm for color (the 500 stems from 1000 micrometer in a mm, with a factor 2 for line pairs: one line and one blank). Elsewhere I found statements that lp/mm roughly equals DPI/100, which for my Df would translate to 3280/24x25.4 /100 = 35 lp/mm, which matches the color calc before. Yes, I read that DPI’s cannot simply be translated to optical resolutions, and that the reason lens resolution is spec’d as it is in in MTF charts is to make the lens tests independent on sensor pixel count, but alas, I am only looking for order of magnitudes and trying to be pragmatic on what I really need.
Hence, would I want a higher resolution camera with a smaller pixel pitch? Yes, perhaps to get an ultimate sharpness from my scans, but whether it makes sense (for me) is a different question. Back in film days, I did not use fancy film, nor could I afford fancy high resolution lenses, nor was(is…) my technique not likely anywhere good enough to achieve laboratory resolution in real-world photography. Hence, for me at least, my camera should be sufficiently good for the resolutions that will be present on my old films.
With respect to lens options, I have a Zeiss 100mm Makro Planar, a Nikon EL 50mm 2.8 enlarger lens that I often use for macro, and the minolta scanner lens, and a blob of other lenses that can be used with extension tubes and bellows. So what gives me the 35 lp/mm that my camera can achieve, and what should roughly be present on my old films?
The Zeiss is very good (Zeiss Makro-Planar T* 100mm f/2 ZF (FX) - Review / Test Report - Analysis) and virtually without errors when used around f/5.6 with about 4000 lw/ph (line width per picture height) center and “planar” with little field curvature (corner sharpness around 3500 lw/ph). A MF negative is 55 mm square, which the Zeiss (1:2 max enlargement) achieves without extension tubes, so for MF 4000 lw/ph would translate to 4000/110= 36 lp/mm, so comparable to what my camera can achieve, i.e good enough. For 35 mm I need to push the lens out by 50 mm, effectively enlarging the projected image by roughly a factor two and thereby halving the resolution: Now 4000/2 = 2000 lw/ph. Since the picture “height” for 35 mm is now the width, i.e. 36 mm, this gives 2000/72 = 28 lp/mm, which is less at 1:1 compared to 1:2 due to the extension, but should be still okay for my purpose.
The Nikon EL 50mm 2.8 I have is lower resolution than its newer “N” version. The latter measures 2500 lw/ph when used pushed out to 1:1 if I interpret the charts in El-Nikkor 50mm f/2.8N lens test correctly, yielding 2500/72 = 35 lp/mm, but I have the lower resolution “pre-N” version, and the lens, despite being an enlarger lens, does not at all seem to have a flat field, loosing ~50% of resolution in the corners. Hence, for me, the Zeiss is better since I do need a flat field for negative scanning.
Minolta specifies the optical resolution of the scan multi ii lens in their manual at 2820 dpi for 35 mm and 1128 dpi for MF. Dividing that by 100 to get (roughly) to lp/mm, it is not really worth to pull it and try it.
Overall, with the Zeiss I would get close enough to my camera resolution and what I can realistically expect to be present on my old films. Would a 4000ED lens or Minolta 5400 lens in combination with a smaller pixel pitch camera yield higher resolution scans? Sure, but whether I would get indeed sharper pictures from my old film stock is doubtful. Hence, my conclusion from this exercise is that what I have, and can presently build together, should be sufficient for my purpose, and it doesn’t make sense (for me, and at least for now) to upgrade my camera or lens solely to scan my old negatives. Whether that remains true now that I am shooting film again remains to be seen though…
Does this make sense or am I wrong in calculating or missing some key things?
Cheers,
Arno
