Just ran a test and D+ (highlight tone priority) does meter the image at X, then adjust to X -1EV only if needed.
I know I would much rather pull a shadow darker than push it brighter, especially considering color shifts. In my bracket tests so far, shadow noise when I equalized exposures (- 0 + EV) to match 0EV and then moved further with the shadow slider is visibly superior in the +1 (or more) exposure this way with no discernible differences in mids and highlights. But lab tests would say otherwise, I suspect. For critical single scans, I am using all manual mode in a completely separate setup/light source and a few test shots, etc., taking all of what I have learned here into deep consideration!
Again, quite the education few days for me.
For bulk scanning, my choice/theory involved a few things, all of which were based nearly totally on speed…
- The noise at ISO 200/400 is functionally not all that different from 100 in practical real world terms.
- The tonal/DR penalty is real, I understand. But… bulk scanning and then doing more critical stuff after makes this difference here less important.
- It also gave me the shutter speed advantage I want because of the aforementioned projector fan vibrations!
- We just can’t have it all, can we! I just want a perfect 100 CRI light, perfect flat field autofocus lens at 1:1 that can scan imperfectly flat film somehow at 2000+ frames per hour providing me a raw file at ISO 100, f5.6, 1/500th, 16bits and 100MP, with perfect color SOOC, hands free, every time without fail y’all! EASY!
It seems likely that you’re correct @nicnilov and I can just set min and max shutter limits to achieve the same purpose without the D+ limitations. More testing! This pushes me more towards to Solux bulbs since they are brighter and I can nullify the ISO 200/400 part of my equasion.
I cannot disable the projector’s fan and its vibrations, at least not yet that I can figure. I did remove the 82V/300W light and installed my own separately powered 12V/7.5W (single point LED) light so it can be on while the projector (fan) can be turned off for in the moment, vibration free scans. Though I lose the ability to advance the slides in this situation and thus bulk scanning becomes tedious, hence wanting to kill the fan entirely.
If I end up with the halogen bulb I will (perhaps!?) want to keep the fan for cooling, but maybe a Solux bulb isn’t so bad compared to the 150/300W bulbs it was designed for! If I stick with my current LED solution, I can truly investigate killing the fan but cannot harm the advancing mechanism. 12v/35W/50W Solux bulbs are going in for testing as soon as I get them.
In any case, the speed at which this can process, hands free, is hard to ignore.
For color and capture, CRI, R9, Lumens, and CBCP (center-beam candle power) measurements all matter. A brighter light is great… but I want to keep my lenses between f4-f8 for sharpness with limited diffraction and not have to use ND filters anywhere in the line.
Such a complicated and fun mess and I will keep saying it - Thank you all for such a lively conversation. I am learning so much about the speed, quality, and time cost compromises that are required!
AS FOR DXO DR and TONAL RANGE
I will do some testing for sure. And surprisingly DXO says R5 ISO 400 is better than 200 for DR but not for tonal range. So I tested it and 400 compares more favorably to 100 when equalized (+/-2EV for either) than 200 does (+/-1EV for either). So strange. I wish I had the resources ($) to test this all against a few other cameras.
I think this has something to do with Canon’s Dual Pixel technology (dual gain) which is hard to utilize efficiently (requires their software, DPP)…
