Converted Scans come in super dark - am I doing something wrong
Hi all,
I was hoping someone could help me figure out if I am doing something wrong in my conversion of this attached scan.
When I first hit convert in NLP, the converted image (without edits made to it), comes in super dark, and only by raising brightness and expose to 30 each will the conversion become useful (I then have to edit the color cast).
I don’t think the negative itself is underexposed, because the final image comes in fine. Before conversion I also make sure to crop the photo tightly, or even just on the subject (the baby) rather than the full image in case the bright background is throwing off the conversion, and it still happens. White balance I also correct using the white balance tool before conversion.
Here is a link to the raw unconverted file, and I am attaching the way it looks after initial conversion without edits (at Type: Negative; Source: Digital Camera; Color Model: None; Pre-saturation: 3 - default), and the edit I was able to come up with after pushing the exposure and brightness sliders all the way to 30.
Is there something I am doing wrong in the initial conversion? It seems strange that it comes in so dark.
I am on NLP v3.1; using digital scanning with a Sony A7RV and the Sigma 105mm macro lens using the Valoi easy120 system with the built in light source.
Thank you in advance!
No problem on my Mac:
Check out the Protocol and NLP settings
Check out NLP’s settings.
Notes:
  1. White balance the scan from the unexposed film base
  2. Crop everything off that is NOT part of the image
  3. I tend to start out with a flat conversion which gives me some latitude for post processing
Thank you; I just tried following your steps exactly and I think that did the trick; looks like the main difference was that I hadn’t cropped in enough (I was relying the border buffer instead leaving a small area), and I had set color model to “none” instead of “basic”.
Going through the steps, I now set white balance using the unexposed border (came in at 2,900 temp, -20 tint), and cropped in all the way as you can see. I then converted as negative, digital camera, basic color model and 1 pre-saturation:
The converted image now looks like this:
I feel like it still looks a little darker than what you got, but a LOT better than what I had before.
Thanks for the help!
You’re welcome.
I recommend to test different settings on both the first and second tab, playing or testing nlp systematically to find a setting that gets close to what you want on as many negatives as possible. The color model “none” is the one I almost never use and different border buffer settings can change the converted image’s look considerably.
note: No set of settings is a shoe that fits all.
I have the same issue with my scans and positive digital files. Every conversion tends to be super dark.
I use this settings
Then I have this raw file straight out of my canon eos R
After conversion and with NLP Standard Preset I got this
Is here anybody with some advise? I trouble with this 1 Year or so and the only way I got this a bit better is by raising up exposure and brightness sliders. But anyway, it is kind of odd and doesn’t look like it works like the example positives from @nate
I have the RAW File here
I realy appreciate any help.
Thanks and greetings
@rich007 , have you tried customising the image with Lightroom’s own tools?
Your contre-jour scene has lots of blown highlight and not many different hues and tones. Moreover, adding NLP into the workflow is not necessary. It can’t “save” your highlights. They are gone as can be seen from a histogram taken from RAW instead of the usual RGB preview.
Hi and thanks for your reply.
So you say, the problem is the scene itself? Not enough hues and maybe with roll analysis and more different scenes the “conversion” would be better?
I wanted to play around with editing negatives with NLP because of the pros Nate mentioned in the last Version. The digital photos are looking from this enginge way more like film as it is the case when I use my film presets I bought.
How do you manage that your digital photos looks like film? I was never able to get the look by hand. When I move sliders half an hour I don’t “see” anything anymore, you know what I mean. If I have a good starting point my I can handle the photo way better.
…things are easy, indeed. To get the good starting point, it takes some experience, luck and/or experimentation. When the first conversion does not work for me, I often create a bunch of VCs that I then convert with different settings in tab 1 and 2
  • pre-saturation set to 1, 2, 3 etc.
  • border buffer sizes or crop variations (e.g. crop off bright parts without structure)
  • my preset with soft highs and lows as well as both clipping points set to -10
  • other…
    Systematic trials help to gather experience, but so far, some negatives simply refuse to cooperate. As for positives: I use NLP to compensate degradations in old slides mostly. Get rid of colour shifts or casts, and NLP can do a lot with such material. And again, some images simply don’t agree with NLP or any other measures - unless you’re after some wild, expressive look.
Systematic testing with different exposure (columns) and pre saturation (rows)
The small triangle with some sky is not blown, but will influence conversion. To limit it’s effect, I set border buffer to 15, which only leaves a little triangle of bright sky.
