You have given the ability to save the current settings as the default. Would like to be able to name my own settings and select them from a dropdown list.
Would like to be able to control the name when a TIF is made. Currently it adds “-positive” I’d like to be able to alter that.
Would like to see a UI that can show previews and saved presets as thumbnails
If you are looking at setting yourself up for another software company to give you billions of dollars for your plugin, everything I mentioned I see in the UI’s of Topaz Software integrated or used as a model.
Great, thanks so much for the suggestions!
- Yes, this is something I’d like to add, its just is a bit complex to do.
- Yes, it is easy to change internally, just need to figure out a way to do that in the UI… it may need to be something that would live inside “plugin manager” as an option, rather than being in the main ui.
- There isn’t really a way for me to do this…
- Haha, yes I would love billions of dollars, so I’ll check that out
