I’m going to mention some keywords in this so that others can find this if they are running into the same problem. Obviously it can be vary between different users that have different setups. I personally am using a Sony a6300 APSC camera, 7Artisans 60mm 2.8 Macro Lens, Viltrox L116T light source, and the Essential Film Holder (EFH).
I’ve been battling the Orange Haze/Vignette/Light issue on my scans since I started digital camera scanning. Some rolls are worse than others. But majority of the time I’ve been able to correct it with Manual Vignette options/Masking in Lightroom. But I was determined to figure this out so that all my future scans were perfect and didn’t need some workaround band-aid fix.
I did quite an extensive test with a different roll of film shot on my Pentax 67. This roll didn’t actually show much of the issue, but I was able to get the Flat Field Correction (FFC) to work properly as it should. I also wanted to find the best way to expose for the negative and the sharpest point of the lens in the process. So I tested my usual f8 at “correct exposure” (±0.0), 1 stop over, and 2 stops over. Then I tested f5.6 at “correct exposure” (±0.0), 1 stop over, and 2 stops over because I was seeing some people say that f5.6 was also another option for the sharpest point of this specific lens. I did these first two tests with Aperture Priority like I would usually for quicker workflow and less fiddling (even though I just use the remote app on the phone to not touch the camera). All shot at 100 ISO.
Then I tested Manual Exposure like @Belinda recommended. Same settings as the first two tests. f8, “correct exposure” (±0.0), +1, and +2. f5.6, “correct exposure” (±0.0), +1, and +2.
I also tested f11 just to be sure of the sharpest point of the lens corner to corner. Also “correct exposure” (±0.0), +1, and +2, but only tested one single frame from the roll (yes, I shot the entire roll for every previous test).
Before getting into my findings, I want to address Aperture Priority. Shooting in this mode at ISO 100, I noticed almost no difference in exposure time comparing it to the Manual Exposure. One of the test that I found to work the best in all aspects (Aperture Priority, f8, ISO 100, +1 exposure comp) was completely identical in exposure time to the Manual Exposure test with the same parameters (go figure). There were only two frames of the 9 frames on the roll (yes, my 67 has the frame spacing issue and is out for repair now) that had a different exposure time. But the difference was only by one click.
This difference had no affect on creating the DNG through FFC nor had any affect on the positive images after being converted with Negative Lab Pro (NLP)
f8, ISO 100 and +1 metering/exposure comp appears to be the best at converting the RAW to a DNG with FFC, created the best exposed images when converting with NLP and had the sharpest results corner to corner.
Any test I conducted at “correct exposure” (±0.0) had issues converting all frames from RAW to DNG for FFC.
(you can see that not all RAWs converted to DNG)
It would convert most of the frames, but would leave one or two frames out. I feel that exposing the negative this way confuses Lightroom in identifying the negative. Exposing +1 or +2 worked every time converting all negatives from RAW to DNG. But images exposed at +2 would be very underexposed and have a difference in color once converted to positive in NLP.
So basically shoot a roll at the sharpest aperture of your lens, at the base ISO of your camera and set your exposure time to be +1 stop over on your metering or exposure comp (whether you want to manually expose or use aperture priority). Then take a calibration frame after the roll is shot by taking your film holder off the light source (I used a frosted acrylic pane over the light source to diffuse the light since the Viltrox has visible LEDs). Upload your images into Lightroom, White Balance, Crop, select all images including the Calibration Frame at the end and select Flat Field Correction in the Library tab.
Here are my FFC settings
![Screenshot 2024-04-07 at 3.00.04 PM](https://global.discourse-cdn.com/standard17/uploads/negativelabpro/original/2X/c/cef47631a39bee1531a74a0362424bd34dd5d47a.jpeg)
Then just convert/adjust/make copies as you normally would in NLP
Lens Sharpeness:
First, comparison between f5.6 & f8, ISO 100, +1
Left is f8 & right is f5.6
Zoom is at 200%. Images have no edits or sharpening, straight out of conversion. You can see that f5.6 gets a little blotchy in the edges/corners (can’t see the grain well)
Next, comparison between f8 & f11, ISO 100, +1
Left is f8 & right is f11
Zoom is at 200%. Images have no edits or sharpening, straight out of conversion. It appears that f11 also gets blotchy in the edges/corners (can’t see the grain well)
Sorry for such a lengthy post. I really wanted to help others and hopefully those with these issues find this helpful. I had so many issues trying to find a resolution online. There are hardly any videos that show this process and damn near no videos that show this process when it comes to film scanning. There are some articles online about this like ( Defeating the Orange Haze - Lightroom Flat Field Correction - An Essential Tool for Digitising Film? - pixl-latr ) which helped a lot. But doesn’t go into such detail or explain what could cause one to run into the issue of their RAWs not converting to DNG.
I’ve gotten into making YouTube videos recently about my film photography and now consider making this a video since there are no other resources out there explain this in detail. I know some people would appreciate a visual version of this test/guide like I would have.
@Digitizer
