Lens to Film Distance Chart: Essential Guide for Different Lenses, Sensors, and Film Formats
“My film scanning setup is almost perfect, but the focus is completely off—not even close—what am I doing wrong?” - that is a very common question on film scanning forums. It typically means that the photographer has placed the film holder, macro lens, and camera at incompatible distances, so no matter what adjustments they make, the image never comes into focus—not even close. It’s often unclear how to adjust the components, especially if they are held together by bellows and/or extension rings. Typically, the solution involves hand-holding the camera and moving it closer to or further away from the film target, trying to catch a glimpse of a focused image. Once you find the correct focusing distance, measure it with a ruler to determine how much your setup is off.
This article is essentially a reference guide listing the typical distances between lenses and film originals for different film formats, macro lenses, and sensor sizes. This is important because it helps people decide on the height of the copy-stand they are building or the total length of the rings connecting the lens to the film holder (like in the VALOI Easy 35 system). Here, I’m offering the numbers based on actual measurements in real life.
SNAG-0000 7-19-2024 10.01.35 PM
I have my copy stand (LPL Copy Stand Column CSC-10) handy, along with three lenses: 50mm, 70mm, and 90mm. All of them are well-regarded fixed focal length true macro lenses—two from Sigma and one from Tamron. I also have test targets for 35mm film, 120 roll film, and 4x5 inch film. I put the camera with the given lens on the stand, placed the film targets on top of the Kaiser light table, moved the camera up and down to fill the viewfinder, focused the lens, and took the measurements with a tailor’s ruler. I repeated that process for both a full-frame camera (Canon EOS R) and an APS-C camera (Canon T8i), using all lenses and targets.
The images of the 35mm frame and 6x9 frame filled the viewfinder completely, while the 4x5” frame fit the width of the view but left some empty space on the long side of the frame.
First, a word about what exactly I measured: one measurement I took was the distance from the lens filter thread to the film lying flat on the Kaiser light panel. This is what you see on the chart as the “Lens to Film Distance.” See the picture for illustration.
The second measurement is the distance from the camera lens flange, give or take a couple of millimeters, to the surface of the tablet, which is essentially the distance to the test target I use in lieu of real film. You will see this data in the column labeled “Lens Flange to Film.” Of course, you may need to distinguish between DSLR and mirrorless cameras as they have different distances between the lens flange and the sensor, but the difference is just 24mm, so that should not affect your copy stand design measurably.
The importance of both numbers lies in the fact that many of these lenses have built-in correction mechanisms. This means the lens is internally adjusted for better performance by moving elements inside to correct aberrations and provide the best flat field of view at different magnifications, up to a 1:1 scale, which is crucial for us. As a result, the length of the lens does not change linearly with changing film formats. Understanding these internal adjustments is important because people need to know at what height they will need to place the camera to capture a certain size of film frame.
By knowing the distance between the lens flange and the film surface, one can estimate the absolute height needed for the camera to be positioned. Additionally, by extrapolating a couple of centimeters between the lens flange and the screw mount on the bottom of the camera, you can get a pretty good estimate of where the copy stand screw should be. This, in turn, gives you an idea of how high the entire column should be and how well it should be stabilized.
Another important consideration from the data in the chart is whether various on-lens adapters like Nikon ES2, Valoi Easy35, or the upcoming VALOI Easy120 will fit your lens and film format. For instance, if you have a 50mm Sigma lens, a full-frame camera, and you want to scan 35mm film, you have only 3.5 centimeters between the lens barrel and the film original. Not many adapters will be able to accommodate that short distance. On the other hand, if the plan is to digitize a 6x9 frame on roll film with a 90mm Tamron lens, you will discover that the total length of the rings you will need is 22 centimeters, which may give you pause as the setup becomes a bit unwieldy.
This is pretty much it. Look at the numbers. In the future, I may provide data for a couple more lenses, like APO Rodagon 4/75, and a few 80mm and 100mm Componon-S lenses, but I think the trend is already clear. However, given that focal lengths of 50mm, 70mm, and 90mm are among the most popular, you should get a rough idea of what sort of copy stand you will need for your preferred film size.
A note about conventional, variable focal length (zoom) lenses: no zoom lens is known to perform well enough for camera scanning, even if they are marked “Macro.” The macro designation on them is mostly a marketing ploy. Yes, you can shoot flowers at close range with shallow depth of field, and the results will be “artistic,” but they will never give you an acceptable image in film scanning scenarios, with or without extra extension rings. This is because the edges of the captured frame will never turn out to be as sharp and straight as the center.
Just to reiterate: for camera scanning, we always use fixed focal length lenses. These lenses may come in camera-specific mounts with full electronic coupling, or we can use certain enlarger lenses (like Componon) or truly excellent lenses from industrial vision systems (APO Rodagon).
The lenses in camera-specific mounts have been engineered to work properly at close range and bear the “Macro” designation. The best indication that a lens is a true macro is the presence of markings on the lens barrel indicating different reproduction ratios up to 1:1. These markings indicate that the manufacturer expects the lens to be used at these ratios and guarantees a certain level of quality. These lenses also have built-in helicoids that extend the optical elements far enough to achieve 1:1 magnification and do not need extension rings. For example, the otherwise excellent Zeiss Makro-Planar 2/100 has markings up to 1:2. True to their word, at 1:1 (which requires an extension ring), the lens performs poorly.
Anyway, I hope the chart will be handy and help you with your film scanning exercise.
@VladS , thank you for your work here, it might help to set up scanning gear more easily when the lens models you tested are used.
A while ago, I noticed that my setup did not correspond to what was expected from theoretical considerations due to lens breathing.
Find more about the consequences here:
I expect every macro lens to have different breathing and therefore, each setup needs to be adjusted individually.
Really useful chart to have as a reference. For anyone wanting to compute the total distance between the target (film) to the sensor then Wikipedia lists the ‘Flange Focal Distance’ for all makes here:
Yes, while I never observed lens breathing , there is such phenomenon and I think that’s why using mirror less camera is beneficial to camera scanning. Given one can double check focus comfortably with aperture set to the working opening the mirorrless can effectively spare one from lot of grief.
I think that you are referring to focus shift, which depends on aperture settings. Breathing is the change of focal length depending on focusing distance.
While mirrorless cams help with focus shift, they do neither good nor bad with breathing.
Wow! Did not know such thing existed. Thanks!
Are each of the film sizes being photographed at a 1:1? Thanks.
Each film was photographed to optimally fill full frame or APS-C sensor. So only 35 mm film while photographed on full frame was shot at 1:1.
What focal length macro lens is necessary to capture 4X5 film at 1:1 at a reasonable lens to film distance? Is there a formula to figure this out? Thank you.
Not sure what you mean when you say 1:1 in re 4x5 and digital camera. But otherwise you can find the data in the chart in the post. Ask ChatGPT - seriously - i recently needed that math for demonstration and it gave me all correct answers, just ask to show all steps.
Thanks for the suggestion re: ChatGPT. Here’s what it offered:
To capture all of a 4" x 5" film negative at a reproduction ratio of 1:1, you need to calculate the required focal length based on the size of the negative and the desired reproduction ratio.
Step-by-Step Calculation:
  1. Determine the size of the film negative:
    The dimensions of a 4" x 5" film negative are:
    • Width = 4 inches
    • Height = 5 inches
  2. Reproduction ratio (1:1):
    A reproduction ratio of 1:1 means the size of the object you’re photographing (the film negative) will be reproduced at the same size on the sensor or film. This means that the optical system must focus on the negative and produce an image on the sensor that is the same size as the negative.
  3. Lens to subject distance (focal length):
    For a 1:1 reproduction ratio, the lens needs to be positioned at a distance from the subject (the film negative) that is approximately equal to the lens’s focal length. For a macro lens to achieve a 1:1 reproduction ratio, the lens must be able to focus at the required working distance, which is equal to the focal length.
  4. Calculate the required focal length:
    Since the film negative is 4" x 5", you need a lens that can cover at least that much area at a 1:1 ratio. The required focal length depends on how much of the negative you want to capture.
    To simplify, for a 1:1 reproduction ratio, the lens should ideally have a focal length around 150mm to 180mm. This would allow enough working distance to achieve the 1:1 reproduction ratio and still capture the full frame of the 4" x 5" film negative.
    Lenses in this range (such as 150mm, 180mm, or 200mm) are typically used for medium-format or large-format macro photography, as they provide the correct balance between the required focal length and working distance.
Conclusion:
For a 1:1 reproduction ratio of a 4" x 5" film negative, a 150mm to 180mm macro lens is a good choice.
…but you would need a 4” x 5” sensor. I think you want to fill the frame of your camera with the 4"x5" film so the magnification will not be 1:1. So for example fitting the 95mm vertical dimension of 4"x5" on to the 24mm short side of the full frame sensor is 1:4, the same on to an APS-C sensor would be 1:6. Both are within the design specification of relatively inexpensive 6-element enlarger lenses.
Surely you want to look at the bottom line in the chart where dimensions are given for both Full Frame and APS-C cameras when copying 4"x5" and those 50mm, 70mm & 90mm lenses.
Let’s have a look at the following:
  • A lens is considered to have a “normal” FL if the FL corresponds to the diagonal of the sensor
  • Shorter FL lenses are more complicated to produce than longer FL lenses of equal quality
  • Normal FL vs sensor size and theoretical distance for 1:1 with a “normal” lens.
Using a longer lens can provide greater working distance and the longer lens might perform better than a normal FL lens. I have a 60mm lens for APS-C and a 100mm lens for FF (and APS-C) and their minimum focusing distances are at 17.5 cm and 31 cm respectively. This means that the effective focal lengths are at 43.75 and 77.7 mm respectively. The well regarded Sigma 105mm Art Macro lens is at 75mm when focused at 1:1.
Well done, ChatGPT! @dsc I tried to hint to you that 1:1 is not what you are looking for, ChatGPT explained it much better than I would do and in less time :wink:
I’m not good with hints. Just be straightforward.
Actually, Harry said what I came to reluctantly realise: unless one has a 4x5 sensor, no amount of optics is going to give a reproduction ratio of 1:1. Correct?
With the Nikkor Z 105 Micro and a 24mm x 36mm sensor, I can capture the whole of a 4x5 negative at 1:3.5. This may be as good as it gets.
Thank you to everyone who weighed in.
It’s as good as it gets with what you have and want. Let’s check again.
  • Printing at 300 ppi, you’d need 1200 x 1500 for a 4x5 inch print. 2 Mpixels, easy.
  • Printing a 40x50 poster at 200 ppi gets you 80 Mpixels. Easy? Use stitching.
