Negative Lab Pro v3.1 - New Color Processing, Support for Slide Film, Improved Batch Editing, and More
NEGATIVE LAB PRO V3.1
New Color Processing, Support for Slide Film & Digital, Improved Batch Editing, and More…
Hi friends,
I’m so excited to finally be able to share this sneak peek with you of v3.1! This update has been in the works a LONG time, with powerful new features to enhance your workflow and expand your creative control over your film.
Also, a BIG “thank you” to you all for your patience and support these past few months… As some of you may know, we live in St. Petersburg Florida, and we were hit with two major hurricanes recently (Hurricane Helene and Hurricane Milton). The storms were pretty devastating and disorienting for not just our family, but for the entire community here. But we are thankful to all be safe and healthy, and that each day brings us a little closer to normal.
Despite theses challenges, I’m thrilled to finally share with you the sneak peek of Negative Lab Pro v3.1!
Download
Want to try NLP v3.1 for yourself?
You can find the latest version on the download page.
TABLE OF CONTENTS
  1. New Color Process Options
  2. Positives and Slide Film Support
  3. UI Improvements to LUTs and Saturation Controls
  4. Batch Conversion and Performance Improvements
  5. Sync-Scene “Match” Feature
  6. Native support for Apple Silicon
  7. Bug Fixes
  8. More on the way!
1. New Color Process Options (LRC 13+ Required)
Version 3.1 introduces a new ColorProcess setting in the “Advanced” settings tab, which offers two distinct options:
  • Classic (Default in v3.0 and earlier)
    This is the same color process model delivers vibrant, dynamic colors with extended richness in shadows and highlights. It excels at creating dramatic color contrast, making small differences in hues more pronounced. It has a tendency to accentuate cool tones in shadows and warm tones in highlights, which can create more dramatic scenes, but could sacrifice some accuracy.
  • Refined: (New in v3.1)
    This is a new option that produces cleaner neutrals, smoother color transitions, and more accurate tonality. This options will produce a more polished, modern look, and will typically provide “truer-to-life” colors, especially on thin negatives or on negatives where heavy editing is required.
Examples
The new “Refined” color process option (right side) can help improve the accuracy of color rendering, especially in the shadows and highlights. Here, it helps remove the bit of blue/turquoise tinting, which is mostly evident in the shadows, and also slightly improves the accuracy of the sky.
(LEFT: “Classic” color process. RIGHT: “Refined” color process)
TIP: On all these photos, you can drag the slider to compare the before and after.
Below, you can see how the left side (using the “Classic” color process) produces lush, vibrant greens, which contrast nicely with the slightly saturated magenta in the skin tones. The right side (using the “Refined” color process) is more accurate to the scene and looks very clean, with pure singular colors. But this doesn’t always mean it’s better… Ultimately, it’s up to you to decide which you prefer for your style!
One more example…
The differences you see will be subtle in most cases, with the refined option keeping the neutrals really clean and providing slightly better color accuracy (although, you may see major changes if the negative is thin).
Here, watch the deep shadows in the water, and the color of the fish fountain. The “refined” option just keeps everything more neutral.
How It Works
The Refined mode leverages the layer mask tool introduced in Lightroom Classic v11. By combining tone curves on both the main layer and masked layers, it gives me more control over how the colors are rendered.
Please note: this feature requires Lightroom Classic v13 or later, as it relies on features which were introduced with that version.
Now, you can use Negative Lab Pro will ALL your captures!
With v3.1, Negative Lab Pro now supports editing slide film and positive digital images. A new option in the Convert Tab lets you change the image type from Negative to Positive or Edit Only:
  • Positive: Great for slide film. This mode offers exceptional control over dynamic range, ensuring natural highlight retention, color integrity, and pure neutrals. It uses the same powerful color correction engine as for negatives, while adjusting for tonal differences.
  • Edit Only: Ideal for quick edits on digital shots, slide film, or previously converted negatives. This skips the image analysis and allows you to go straight to editing.
Why use Negative Lab Pro for Slide Film or Digital Images?
Of course, you do not need Negative Lab Pro to process positive images in Lightroom.
BUT, I have found that there are some clear advantages to using Negative Lab Pro with positive images.
1. Better Tonality Control & Highlight Retention
While Lightroom by default tends to push highlights (in a way that is virtually impossible to get back to neutral), the pipeline in Negative Lab Pro keeps the tonal response linear in the earliest stages, making it easier to get natural tones and maximum dynamic range.
2. A Purer, Simpler Color Pipeline
I’ve had to be very careful with the way I designed the pipeline in Negative Lab Pro, because any small mistakes become exaggerated when the negative is inverted and normalized to full dynamic range. I’ve found that the profiles that come with Lightroom by default are doing too much too early in the pipeline, which causes problems further down the road when you begin editing. By keeping the camera color profiles as simple and precise as possible, and being very careful about the order of operations, it’s able to produce fantastic results.
3. Access to NLP’s Unique Editing Controls
There are some editing controls that you really just can’t do directly in Lightroom (unless you have a lot of time and are really good at math). Things like the brightness slider (which is a precise gamma correction) are not directly possible in Lightroom. The same goes for many of the settings in Negative Lab Pro which work uniquely and would be difficult to do directly in Lightroom.
Examples
Here’s a perfect example of the color and tonality improvements with Negative Lab Pro, on a camera scan of a Fuji Provia slide.
LEFT: Original Camera Scan in Lightroom. RIGHT: Processed with Negative Lab Pro
On the left side, the initial Lightroom interpretation has blown out a lot of the rich color, texture and details of this Fuji Provia slide. This is happening so early in the pipeline that it is really impossible to get it back exactly as it should be. Look at the missing details in the brightest section of the wall, the tops of the umbrella, and the missing color and details in the blue shirt of the gentleman on the left side. Using the “highlight” slider, you can try to get this back, but it will not be exactly as it should. You may also notice some subtle “hue shifts” in the hue of the yellow wall in the brightest section and darkest section. This is happening because of hue twists in the color profile itself. This is impossible to undo directly.
On the right side, this is processing it through Negative Lab Pro… in this case, it basically looks like I’m looking directly at the slide on the light table. The dynamic range is perfect. The hues are pure and simple with no shifting. All the color and details are there from the start. Move the slider to the left and see how the rich detail and color are there, exactly as they should be.
Here’s another film slide example:
On the left side, just opening it up in Lightroom has gotten this pretty close, but there are still a few issues. First, there is a slightly green tint to the whole image (which is visible on the slide). While it is possible to use the White Balance tool in Lightroom to correct for this, that is not the ideal way, as the dual-illuminant profiles will also try to adjust the colors and not just address the tint. And second, there is some loss of fine detail in the shadows. While it is possible to bring some back, you are losing some of the naturalness of the image (because the internal curve causing the loss of the shadow detail is different from the tool being used to try to bring some back).
On the right side, Negative Lab Pro has dealt with this very naturally. It corrects the green tint (without throwing off any other colors), and does a better job of maintaining the shadow details and colors. They are small details, but they do add up and make a difference!
Ok, let’s look at a few digital image examples.
LEFT: Original Digital Photo Import into Lightroom. RIGHT: Processed with Negative Lab Pro
I find on brighter skin, Lightroom (left) tends to wash out the skin and cause some unnatural highlights. The differences here are subtle, but I find the colors and details here through the Negative Lab Pro pipeline (right) to just take everything up a notch.
One last example, just to show how dramatically this method can improve highlight detail in digital files…
On the left, Lightroom has really massacred the fine detail and color and in the highlights of the flower. And there is no way you can get this back properly using Lightroom’s controls! The muddying of these details happens at a very early stage in Lightroom’s normal pipeline. When you use the “highlight” slider in Lightroom here, you are just making this muddiness less bright.
On the right, Negative Lab Pro has brought out the intricate colors and details as they were meant to be.
3. Enhanced LUTs and Saturation Controls
I’ve never been happy with the previous implementation of the HSL LUTs and Saturation control. The new UI makes it so much easier to control the intensity of the LUT you are applying, as well as the saturation.
  • Adjust HSL correction intensity with a simple slider.
  • Control saturation levels without navigating dropdown menus.
Easy-peasy!
Faster and More Stable Batch Processing
With significant under-the-hood memory optimizations, you can now convert hundreds—or even thousands—of images in one go.
There will still be some limits just based on your specs, but for example, on my 2019 MacBook Pro, I can now process over 500 images in one go with no issues.
5. Match Feature
Bringing Back “Sync Scene” as “Match”
The much-missed Sync Scene feature has returned, now renamed Match. Match takes the settings and image analysis from one negative and applies them directly to the rest of your selection—perfect for ensuring consistency across a batch of images.
6. Native Support for Apple Silicon
This has been a big request from Mac users, and now, Negative Lab Pro runs fully natively with no need for Rosetta. You should notice some speed improvements during conversion (partially due to using a native Apple Silicon build, but also due to other memory improvements).
7. Bug Fixes
General Bug Fixes
  • Resolved Windows licensing issues causing frequent drops.
  • Fixed syncing and copying errors that caused settings to fail.
  • Updated camera calibrations to match Lightroom Classic’s latest release.
Ongoing Issues
  • I’m still working on an issue affecting Intel Mac users running the latest Lightroom Classic and macOS versions. Until resolved, I recommend using Lightroom Classic 13.5 for stability.
8. More Improvements Coming Soon
A key feature I’ve been developing is auto-cropping for negatives, which will now be released in v3.2. I was really hoping to have it all done by now, but recovering from the hurricanes has really set me back on time.
Stay tuned for further updates and improvements!
How to Try the Beta Version
You can download the latest beta version here:
Just run the installer, and you should be good to go. If you run into issues, please let me know in the NLP v3.1 Beta Issues thread.
Whew, that’s a lot of updates! Let me know what you’re most excited about in the comments below. Thank you for your support, and happy editing! :folded_hands:
I can imagine and I suppose you started fixing things that are pressing and important, not that I’m trying to say that NLP isn’t. Many love and use it and are keen to see the new features in action.
I do hope that NLP 3.1 will run on Apple Silicon computers without Rosetta… :face_with_hand_over_mouth:
Thank you for working on those upcoming updates! Auto-cropping is something I think about a lot, really excited for that.
All the best in your recovery from the hurricane! I’m very happy to hear that NLP will now support slides—this will be a real game-changer for me personally.
As you update the documentation for the new release, would it be possible to address best practices related to camera scanning technicalities? Specifically, topics like the optimal light source (e.g., continuous LED light, trichrome, sunlight, halogen lamp with a naturally broad red range), the best capture density, and methods to assess if the digital image achieves the optimal density range for conversion.
All the best, @nate. I can’t wait for the new release to become available. Thanks so much for all your work!
Fantastic effort, and fantastic results.
I’ll be happy to get back into the slides this winter. Thanks so much.
As @VladS mentions: Slides…yes! One can wonder why NLP would be needed for a scan that’s already positive, but once one tries to match a scan to what is seen on the light table, it becomes very clear that it’s hard to match the dynamic range and colors. All in all, my slide scans seem so “ugly” that I stopped using Velvia and simply gave up. Indeed, there seems to be “stuff” that LRC does to the images which ain’t good. Yes, I tried to import using linear profiles, but I can’t seem to match anywhere close to the slide itself. Looking forward to find if V3.1 will do a better job!
In plan for v3.2 is the ability to use your own installed version of ImageMagick and ExifTool (rather than the ones that come packaged with NLP), in which case you could avoid using Rosetta.
Agreed! I’m eager to get this out, but the past few months really set me back on this.
There is a lot of info on this in the forums (thanks in part to you and others in the community who have contributed!) so it probably would be good to bring more of that into the guide. The flip side is that I don’t want to overwhelm newcomers. Perhaps I can add some more guides for advanced users, and I’d love the help of you and others in the community to do this!
Yes! Lightroom is pretty “opinionated” with how it works under the hood. It isn’t hard to edit to get slides “OK” in Lightroom, but it’s basically impossible to get it “perfect.” Can’t wait to get this out broadly and see what the community can do with it!
If any beta testing needs to be done, I would like to put my name down for it. Excited to try these new features out!
Bravo Nate!
Thank you for your great work. I look forward to testing.
Nate,
Super impressive as always!
I know that the core of the user base is camera scanners. But there’s a fair number of us still out there scanning to TIFFs and it would be great to have some real support and proper profiling. Myself, I always scan “raw” TIFFs with Nikon Scan from my Coolscan 9000ED and merely adjust the “analog gain” setting to get full range coverage on each RGB primary. I have presets for each emulsion. Other than that the scans are “zero colour management” and come out with no profile. But the profile I assign (or leaving it unassigned which pretty much equals sRGB) does have quite an effect on the inversion. And I’ve been getting a good education in the forums and in various articles about how the cross-talk problem can be dealt with by LUT profiles. The Coolscans do have narrow band RGB illumination but, as I understand it, a standard matrix profile doesn’t reflect this. You basically need a LUT profile that will “reflect” the lack of cross talk or you get a related colour inaccuracy problem from the matrix profile implying broad spectrum illumination. I know this is pretty geeky but a lot of us are in this boat with only a few main devices (Epson flatbeds and Nikon Coolscans are used by a lot of film folks). Wondering if there might be some profiling that might kick in if we identify that this TIFF came from this scanner. Or even better, some tool to make such a correction LUT using a scan of a (photo of a) ColorChecker or something.
Anyway, great to see you still hard at it and can’t wait for the new version!
Sam
I can’t wait to test the new color rendering and slide processing!
Is the workflow for scanning with Vuescan still valid for slides? In particular Media=image and Lock exposure for slides from the same film?
With this information, I’m already preparing my scans to test the new version!
Best regards,
Patrick
Very excited for the slide film option. Currently it’s alot of working against LR instead of with it.
What’s the preferred source material for slides in NLP when using Silverfast? I usually just scan them as positives in DNG.
I hope your life is getting back to normal. My brother lives in Miami and escaped this time. Stay safe.
Given the clearly more important priorities you have on your plate, I will gladly wait for auto-cropping in v3.2. Living in a floodplain and dealing with yearly flooding, I am glad you and yours are safe!
Incredible upcoming features Nate! Looking forward to the more color accurate mode! All all other teased improvements! All the best for you and your family
I’m looking forward to trying the new features when you are able to make the next release available. From your description they appear to be very useful. Most important, best wishes for a speedy recovery from the hurricane damage. That is all so regrettable. Be well.
Mark
@nate I haven’t shot as much film lately and I didn’t know you and your family were affected by the hurricanes. Just wanted to thank you for the work you put into NLP and wish you and your family a speedy material recovery (given that thankfully healthwise you guys are doing well)!
I invested in C1 as I was tired of paying a whole lot of money for an Adobe subscription that’s also impossible to get out of without paying it all, but, given that I’m shooting 95% digital now, the feature I’d be most curious about is the editing of digital RAWs!
Do you change the color temperature of your light source when scanning?
I use the Valoi Easy35 and they recommend the warmest setting possible for slide film. I’ve also seen others shoot it with an orange filter over the lens to warm up the image.
Very excited for all of these changes!!
Hi Nate and others,
Just found out about ver 3.1 via an email from Nate. I have ver 3.01 and wondering if I need to buy the update to 3.1 or it is a free upgrade for 3.01 users
James.
If you have a license for v3.0, then v3.1 is a free update for you. :+1:
