Option to place "positive copy" image on top of stack by default
I use a positive TIFF copy of all of my scans as part of my workflow, and part of that workflow involves moving the positive image to the top of the stack after I create them. I certainly would find an option to create the positive image at the top of the stack instead to be a very helpful option.
Thanks for your work on NLP!
I would also like this
Yep, that should be pretty easy for me to add to the next version :slight_smile:
-nate
This is not working for me. When I select “Stack (below)”, it creates an expanded stack in the correct location with converted RAW file first. When I try to swap the order of the stack, it moves it to the end and I have to manually move back to where I want it. When I select “Stack (above)”, it puts the expanded stack at the end. I then have to collapse stack and manually move it to it’s original location.
What I would like is to stack the positive TIFF on top of the converted RAW in it’s original location. Is there an way to do this automatically without manual intervention?
