I recently contacted skier to purchase the copy box 2, and was directed to one of their distributors. For anyone interested, their taiwanese distributor is selling it for cheaper at 160usd. But according to the guy I spoke to, the copy box 2 is currently out of stock and theres a copy box 3 on the way. Any one has any information about this new iteration? Also, does anyone know the difference between the 1st and 2nd version? @nate@Richard1Karash
Yes it is a great tool. I used a Bencher copy stand from 1980 to 2012. The first eight years, I was a multi-image AV producer, copying thousands of yearbook pages for editor training workshops, along with lots of slide duplication and special effects work. The Bencher was key in all of that. I wore out a 55mm f/2.8 Micro Nikkor on my pin-registered F3 with that setup!
I used it off and on as I had eight other jobs at the same company, eventually using it heavily again with digital cameras from 2005 to 2012. I replaced the quartz peanut lighting system with two Westcott TD-5 Spiderlites with 27 Watt photo grade daylight fluorescent lamps in them, and two 32x24 inch softboxes with two layers of light diffusion. That got rid of all copy glare, by making everything a highlight.
Folks, If you can find them, used Bencher copy stands are awesome.
I am considering between the similarly priced Negative Supply 5x7 Light Source Pro (unfortunately only the 95 CRI version as the 99 CRI is out of my budget) vs the Skier Sunray Copy Box 3 Panorama (135+120+45). I understand that I’ll be able to shoot 135, 120 & 4x5 on both of them and that the CRI is more or less the same (95 vs 94). While the Skier does come with film holders I already have Digitalizers for 135 and 120 and anti newton glass for 4x5 so that doesn’t significantly alter the equation for me.
Does anyone know their relative brightness and how collimated the light of each is?
So apparently v3 now supports panoramic mf film, 6x12 is supported which isnt very appealing to me. But I have noticed that they have changed the light source here is some info from their website:
Copybox 2 Zen:
5600k
18w
97CRI
1250Lm
1 stage switch
Copybox 3 Panorama:
5500K
22W
94CRI
2600lm
3-stage switch (25%,50%,100%)
What do you think of these changes? Do you think it will still be a good light and a good product worth buying? I was going to buy the v2 but a retailer was out of stock and told me to wait for v3 but v3 is more expensive!
I thought this was interesting as well, but most likely I doubt there will be any significant difference in the quality of light from the new panel. I am also surprised at the increase in brightness considering how bright V2 is (my current settings are ~1/320th, ISO 100, f/8).
Like you, I have no need for any of the “upgraded functionality” that comes with V3 as I only shoot standard 35mm and medium format up to 6x7, so I am lucky that a second-hand V2 popped up for sale just after Skier sold out of their crop of V2s and before they announced the V3 box.
Might be a long shot, but may be worth reaching out to them directly to see if they are able to sell you a V2 if they have any leftover parts/stock, or at least a V3 box with V2 holders if that’s an option.
Hi everyone.
Wondering if anyone had comparisons between Skier and Negative Supply gear?
Also do both systems allow you to include sprocket holes in ‘scans’? If so how much of the film borders is possible to include?
Hello everyone!
I’ve been reading this entire thread and others on this forum and i learned so much!
Until last week i never new CRI was a thing… But now looking to buy a light source i stumble upon TLCI score.
Is it important for film scanning ? Should i care ?
Yes this is it. It looks like TLCI important for color rendering in video recording… But does it matter for film scanning ?
Or am i really nitpicking here ?
I found this page with a huge database of CRI(Ra) CRI(Re) TLCI and some more color accuracy score for LED light source https://indiecinemaacademy.com/understanding-complete-led-database-testing-procedures/
I’m kinda overwhelmed with info right now…
Interesting page, thanks. According to those measurements, the highest light quality, dual-digit priced light is the Aputure Amaran AL-M9. I’d suppose that the light needs some extra diffusion layer(s) that will swallow some of the output.
Yea, definitely still interested in the v2, no need any of the pano functionality for now, but im not sure if they will continue to make v2s, hopefully they do, and not just offer the v3 from now!
I was wondering if it would make sense to set the screen of my ipad to some off-white color to offset the orange cast from the film to get more dynamic range in the reds (edit: i meant greens and blues)?
I’ve been asking myself this question and tried it by taking, with my iPad, a shot of the orange mask. Then, I inverted the shot and displayed it as a backlight.
I found that it made not much of a difference, also because contrast of negatives is relatively low. Although the blue channel gets less light, it is still good enough. ETTR can help too.
Hi! I have a Solux 4700k, but so far I can’t figure out how to get the most uniform diffusion on the negative. Who managed to get it with halogen bulb?
Try the following things separately or in combination To get a more evenly lit negative
Move the bulb away from the negative
Insert a diffuser between negative and bulb
Indirect lighting: Shine the light on a white surface behind the negative
All of the above will require longer exposure. Intensity drops with the square of the distance, which means that doubling the distance will cost two stops approximately. Some of it can be equalized by shining the light through a tunnel that you could make from a can for instance.
