the orange masks makes the blue channel darker. So this channel in particular is prone to posterization
In other discussions I have found the suggestion to use a blue filter in front of the lens of the DSLR. It would shift the color balance in favor of the blue channel. When looking at the histograms of negatives captured with my DSLR without the blue filter, I cannot detect a significant shift of one of the three channels in Lightroom. Therefore I’m not sure if a blue filter will be helpful or rather a bad idea.
Has anybody used such a filter or does anybody have an opinion about using one for “scanning” film negatives using a DSLR?
I’ve used a color head from an enlarger and tried to compensate at least some of the orange mask by setting the C/M/Y filters accordingly. While the film base was as neutral as I could make it, the converted images did not look much different from the ones taken without corrections. NLP does a pretty good job in getting you a decent starting point, no matter what kind of (good) light you use. My conclusion was that it was not worth the effort.
I’ve also tried with an inverted shot of the film base as backlight on an iPad. Same conclusion.
As for the idea of getting the blue channel out of the noisy corner, a bit of overexposure will do that too.
Expose to the right, keeping highlights a bit away from the right edge of the histogram. Colour negatives tend to have low contrast and therefore allow for some overexposure.
You can find some background info/hints on related techniques by searching for “ETTR” and “UniWB”.
A lot of ideas and tests are documented in this part of the forum.
That’s interesting, because my attempts to improve the result by using a blue filter didn’t show any significant differences. And as I mentioned before the histogram also didn’t show the necessity to shift the colors in any way. All channels were exposed quite evenly, but with the blue filter it was significantly off.
The other plugin I have used so far requires the conversion of RAW files to linear TIFFs. using a dedicated executable. The result in a quite big file that looks very green’ish. I have experimented with UniWB in the past and I have created a white balance for UniWB, which is the only reliable way to assess the exposure of the different color channels. However, I wouldn’t want to use that WB setting for actually taking the shots. Actually I would take a black photo, which basically shows the pure orange layer, use the UniWB white balance setting in the camera to set the exposure correctly. This would be the ETTR approach based on the maximum brightness possible. Of course individual photos can be darker and lack these brightest possible values. Ideally you would use UniWB again for each photo to figure out the optimal exposure based on the histogram.
Thanks for the link to the page (which I have already studied of course… ).
I use the UniWB setting while taking the shots. It makes the previews look green instead of orange but the sensor gets exactly the same amount of light (at equal exposure)…
After manual WB, both shots look the same.
Sure, it will look the same once the preview is updated in LR. However, my latest idea was about using the digital filter “invert color” and then store the images in RAW+ mode, which means one JPG with already inverted colors and a RAW file alongside. However, I haven’t yet tested the “invert color” filter with negatives. I could imagine that it doesn’t automatically remove the orange mask, but I’ll have to test that. For a RAW file I would actually go with the UniWB as this provides the only safe way to assess the exposure without downloading the image to the computer. Interesting to see that others are using UniWB as well.
I have read an article of someone who said, that he had definitely better color separation results with using a blue filter. But he wasn’t using NLP and i don’t know what he was using as light source. But to me this makes sense. Without a filter the blue pixels in the camera get underexposed.
I think it depends on the dynamic rang of the camera, wether this is a problem or not.
Many blue filters have humps and bumps like shown on this page
Adding humps in the filter curves changes balance between not only R, G and B colours, but also of all hues in between R, G and B, which can impair the desired colour rendering (as in lowering CRI and TLCI values). Digital cameras are thought of separating R, G and B cleanly, but “red” pixels also record some green and blue light (and hues in between) etc.
Adding a blue filter might help in some constellations, if yours is in such a case is easy to find out: Try it.
One interesting detail about my RAW files from negatives: I’m using the software “Fast Raw Viewer”, which is one of the care programs that will allow you to view the actual RAW file instead of the JPG interpretation. And it’s capable of showing the histogram of the RAW file, not only of the resulting JPG (embedded preview). I have inspected some of my shots using it and in fact the blue channel is a bit “behind” the other two, but not by far. I have seen that my attempts with the blue filter were way over the top in terms of compensation for blue. Of course you could try to find a blue filter that is just strong enough to provide you with the most uniform color channel levels, but then again: there doesn’t seem to be much indication from my tests and from @Digitizer that this would improve your conversion results in a significant way. Considering the potential problems a color filter could add, I’m rather conviced and determined to continue without one for the remaining negatives.
It’s as always: if you really see a problem with the quality of your pictures, go for this potential solution. But not just for the sake of a more evenly looking histrogram that might not have any visible impact on your results. Using the RAW format when shooting your negatives seems to be enough in terms of headroom for your captures. Keeping it simple is often key. A filter can also result in inferior optical performance of your lens. I prefer the most clean signal path and think I’m getting very good conversions this way.
The Pakon 135 scanner is known for its great power to scan film negatives but it’s not good at all when it comes to slides. The reason? It uses a blue light source, and this exactly to compensate for the negative warm tone. So, although I haven’t tried this yet, I am thinking of setting my video light to a colder white balance when scanning negatives and see how it impacts the results.
Before using NLP I was using a double CTB gel on my light source (flash). This was only to prevent clipping because the dynamic range of the negative with orange mask was too large. (Very bright red channel and dark blue channel).
Later I have been doing comparisons with NLP (gel vs no gel) and I’ve seen very little difference.
