So I am still confused and don’t know whether I should use the ‘Adobe Color’ profile or another one when I edit my scans of slide film. I am trying to find the NLP Natural profile or whatever it was called. I just want the most accurate color profile to start with.
I have NLP 3.0
Macbook Pro
Lightroom Classic 14.0.1
You can find the natural profiles in LrC’s Develop module under “Presets” in Lr’s left sidebar.
Pick any profile that makes your images look like you want them to look. Whether applying a profile before NLP is used makes sense or not, you’ll find when you check the profile that is used by NLP. This info can be found at the top end of the basic settings tab in Lr’s righthand sidebar of the Develop module. As of now, the guide has no chapter on slides yet, but you might want to check it out nevertheless.
Other than that: Try, observe and learn how to do the things that fit your bill.
NLP 3.1 has a native slide function, but would require an upgrade. Test it out and decide if you want it. Works great.
This topic gets spoken about from time to time but here is what I landed on after a long, in-depth conversation that got deep. I have stuck with my version for most slides except the occasional problem child. Here are my DIY version examples.
Linear from the new version (3.1.1 I think) should be the one. check whether you have the latest version of NLP, otherwise you wont have the “Positive Film” option in the “Conversion” step.
Hey, I thought maybe you can help here. So I got the new v3.1.1 of NLP and after importing the RAW file of the slide scan and opening NLP, doing all the editing steps, I see that the Profile has switched to NegativeLab v2.3. I wonder if this is correct and why it isnt called NegativeLab v3.1.1. I just want to make sure all the automatic steps in my workflow are correct, even if I decide to use a different profile.
Versions of NLP and NLP profiles are numbered independently. The plugin version is indeed what one expects: a version number. With profiles, the version number means that this kind of profile was introduced with a version of NLP that had the same number. Profile version numbers also help NLP to pick the right profile dependent on which version of NLP is in use.
Profile v2.3 was introduced with NLP v2.3
→ these profiles can be used by NLP v2.3 and newer, e.g. NLP v3.1.1
During its development from version 1 to today, NLP’s algorithms have changed and some of these changes required the profiles to be adapted and re-numbered to prevent duplicate names.
