Changes not seen until I hit apply and open the edit windows again
When I move a slider, nothing happens. I can only see the change after I hit apply and the open the window again. It only happens with sliders. If I choose a tone-profile or wb setting from the drop down menu, I can see the photo changes instantly. Same with pasting settings.
Graphics acceleration is turned off
Not seeing that here on W10.
There’s sometimes a small delay in seeing the effects of the sliders, but they do work for me.
Are you on the latest version of NLP (v3.1.1)?
Are you on the latest version of Lightroom Classic?
Is this happening in the Library of Develop modules?
Does this happen if you go to the “advanced” tab and change the color process to “Classic”
I am using the latest version of NLP and version 13.0.1. of Lightroom Classic. It’s only happening in the Develop module but it does not happend at all if I choose the “Classic” color process
Nice to see I am not the only one having this issue ! Keep the color process to Classic indeed solve it but the Refined one is so much better I have to invert in the library pannel, which is painfully slow…
@nate Do you have a solution for us ? I would love to be able to use NLP as usual…
Up. Please I am still hoping to find a solution, Refined is so much better than classic I want to use it…
Can you try upgrading to the latest version of Lightroom Classic and see if that fixes your issue?
Also, does it work in the Library Module?
I don’t have this issue with the current NLP 3.1.1, LrC 13.4, macOS 14.8.1.
___
Note that I’ve also tested with other versions of LrC and macOS a while ago. I don’t think I’ve seen the issue in the last (10?) months.
