Hello,
I’m quite new to film scanning but I want to provide scanning service in NYC with Fujifilm GFX100 series as a side job. Besides, I also shot tons of film before which I never digitized them so at least I have multiple purposes to pursue.
My main goal is to be able to scan 35mm, 120, and 4x5 film with GFX100S and Pentax 645 FA 120mm F/4. I researched about this quite a lot and I would probably need a copy stand, film holders, light source, and etc. My budget is quite tight so I cant spend too much money on the kit while I dont want to sacrifice a lot. Negative Supply looks nice but not my option so far.
There are several questions due to my camera as many film scanning accessories dont really support medium format lenses and sensor size. Negative Supply’s equipments seem nice but totally expensive for sure.
My questions are:
- Is there any option that I can use a flash light instead of LED light source?
- Any other systems instead of Negative Supply for the copy stand, film holder, and light source that I can scan 35mm, 120, and 4x5?
- Does any LED light source can provide enough brightness for F/8, ISO 100, and slow shutter speed?
- How do you calibrate the white balance since the color checker is not transparent?
- Does the light source works with an electronic shutter?
- How do you parallel the camera and the holder precisely?
- How can I keep the environment clean from dusts as I scan films from my room?
- Do you think that I need a wider macro lens for some films?
