Has anyone had issues with vibration that they were able to solve, outside of moving their rig onto a solid concrete floor away from traffic?
My first-floor studio overlooks a busy road with HGVs rattling past. I can scan after 8-9pm and that helps, but I was thinking some kind of vibration damping mat could help, directly under the copy stand and/or under the cabinet the copy stand is sat on.
If you could somehow contrive to attach your negative holder to your camera/lens setup along the lines of the Valoi easy120 that would make it much more immune from external factors. Similarly making sure that your current copy stand setup is as rigid and solid as possible of course.
I’ve played around with flash from time to time, indeed I started out using a Bowens Illumitran unit which is designed around high intensity flash (too high but that’s another story). That has a separate viewing/focusing light source, you switch from one to the other using a lovely large rocker switch on the front. How do you handle that aspect in your setup if you don’t mind me asking?
Here’s my 35mm copying setup. It’s a Nikon PB-6/PS-6 with a 55mm Micro-Nikkor f/2.8 and a Canon R5 with Novoflex lens adapter. It’s lit with a Profoto B1 strobe. these were just shot with an iPhone, so the yellow light emitting from the Profoto is just the modeling lamp.
If I was going to do a vertical copy stand set up I would have a cutout stage at the table for a diffusion panel and the strobe under the table.
Right, thank you, a studio strobe with a built-in modelling light (a very good one too!). Of course, that will work very well. There are a few examples of the ‘under the table’ medium format setup in the long ‘Let\s see your DSLR scanning’ thread if I remember rightly. Very nice.
Sorbothane has always been used by high end hi-fi enthusiasts, and with prices to match, but I see that it is now needed by those using 3D printers to ensure that their projects are not disturbed during the long hours of printing. They seem to favour putting their printers on a heavy slab and then mounting the sorbothane pads between the printer and the slab.
The way you rig is constructed also greatly affects the sensitivity to vibration. Say any tripod-based approach would be worse, copy stand and camera suspended on the long arm is not much better, but those setups where camera , lens, film holder and light are all mechanicaly bound together would fare much better. Examples are vintage slide copiers with camera and lens mounted on bellows and film holder bound with massive metal rail or Valoi easy120 would be almost impervious to vibration. My 2 cents.
I’d try isolating the enlarger or scanner from the floor vibration first, using a heavy, stable base with proper vibration-damping pads underneath. The key is to avoid anything too soft that could introduce wobble of its own. It’s worth testing with a few scans or exposures to see whether the improvement is noticeable.
The point about rigidly coupling camera, lens, and film holder makes sense — if everything moves as one unit, floor vibration matters far less than when a long arm or tripod amplifies it. I’d second starting with isolation under the base rather than soft foam, since something too squishy can add its own sway. NBR matting seems reasonable for small high-frequency movement, but a heavy slab with firmer pads might suit a scanner better. Testing a few identical scans before and after seems like the practical way to tell whether any change actually helps.
