Green/Teal Fog only on certain photos
Hello, I scanned in a roll and have this weird green fog on either side of the photos. I think I saw an answer somewhere about clipping the orange? I can’t find it though. I scanned in full darkness and this isn’t on every photo.. (Excuse how bad this particular photo is, ha. The teal was there even when I had it correctly colored, I’ve been messing around with it) Any ideas? Thanks!
Using V3.1.1
tone carrier pro film carrier
canon r6 with nikkor 55mm 3.5 and negative supply co 4x5 light source mk2
Using lens hoods in a dark room with a dark sheet over it
My guesses…
  • Looks like the green fog is denser at the top and bottom parts of the image, which hints at some stray light or internal reflexion (considering how you scan your images)
  • The scene looks like it was taken in mixed light and a flash. Such conditions can lead to effects as in your scan/conversion. Some of it could be corrected with local adjustments (gradient mask and WB hue shift?)
Also, NLP’s outcome depends on many things, There are a lot of settings and crop or border buffer can make a big difference.
For further hints, it is helpful if you posted the original scan and NLP settings, be it as attachments or as a download on a file share or sharing service like wetransfer.com or anything else that can share the file without us needing a login.
