How to use Match function?
I have two frames, a stereo pair, and I’d like to match the conversion (ie, I did one NLP conversion that looks good, now I want to do the exact same conversion to the other frame).
I see that a Match function exists, as it’s mentioned here. But I can’t get it to work. I have selected the two frames in LR, and opened NLP (3.1.1), but I don’t see a match button/control; please help.
Not used it myself but it is mentioned by Nate here as a resurrection of the old ‘Sync Scene’ feature:
…..and then I had a bit of a discussion with @Digitizer which seemed to reach the conclusion that ‘Match’ doesn’t quite do what it says on the tin.
However since your stereo pairs are absolutely identical of course I think it would work in your case.
Thanks for the replies; I still don’t see how to use it though. If I select 2 photos in LR, and open NLP, I should see a match option somewhere, right?
If you have more than one image selected, and the “main” selected image has been converted already, you should see the “match” option appear below the settings.
Thanks Nate; I had multiple images selected, but still wasn’t seeing those text buttons under the settings popup.
Please add a screenshot of what you see when you expect to see “Match” .
I meant I wasn’t seeing them before, since you sent the screenshot I am seeing them. Thanks for your help.
