This sounds great. I have a couple thousand images that I can upload of various sizes. How many would you like?
Peter
Peter
This is great news. Hope it’s progressing well. Would it also be able to straighten the scans? I never seem to be able to scan perfectly level, usually less than 1° or 2° but that still makes quite a difference. Being able to decide how much rebate is kept would also be useful.
Feel free to share as many as you’d like, but I think 100-200 per setup should be good for now… also as part of the training I’ll have it generate variations of the existing, so it will augment the data and make the learning process more robust.
Yep! My goal is to include:
They are already there in Lightroom…but it looks like Lr is “searching from inside out” for perspective corrections. If it can be made to search inwards instead, the transitions between rebate and image should be easier to detect, except for thin or dense negatives.
(Scanning 645 negatives in a digitaliza holder gets me borders that appear black or white respectively)
Hello,Nate
I just wanna know will the "auto crop"function update recently?
Really need this tool.Thank you!
I took another path instead of filling the exposed area.
Basic idea of mine is that
(0. compress the image, my GFX scanned is too detailed for edge detecting)
Note that the dilate step is very important because without dilate, it might treat a single image into several ones due to the transparent area (or dark areas after conversion), see example below:
The amount of dilate (kernel size) may vary on different images
One issue is that for a negative that is very dark, especially night pictures (for example, picture of fire works), it won’t be able to correctly crop, as the edge of the frame is unclear. This is kind of an issue, but for most well-lit images, it works fine.
For example, only the upper area is being cropped for the below picture.
I’m very very new to opencv, just a couple hours of exploration, but I do believe that this auto crop is an essential step for making the process faster.
Code below:
import imageio
import rawpy, cv2
import numpy as np
input_file = ("XXXX.RAF")
with rawpy.imread(input_file) as raw:
o_image = raw.postprocess()
image = cv2.resize(o_image,None,fx=0.05,fy=0.05, interpolation=cv2.INTER_AREA)
gray = cv2.cvtColor(image,cv2.COLOR_BGR2GRAY)
blurred = cv2.GaussianBlur(gray, (5, 5), 0)
edges = cv2.Canny(blurred,0,30)
cv2.imshow("edges",edges)
cv2.waitKey(0)
kernel = np.ones((2,2), np.uint8)
dilated = cv2.dilate(edges,kernel, iterations=1)
cv2.imshow("dilated",dilated)
cv2.waitKey(0)
# Find contours
contours, _ = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
cv2.drawContours(image, contours,-1,(0, 255, 0), 1)
cv2.imshow("contours",image)
cv2.waitKey(0)
largest_contour = max(contours, key=cv2.contourArea)
# Get the bounding rectangle
x, y, w, h = cv2.boundingRect(largest_contour)
x,y,w,h = int(x/0.05),int(y/0.05),int(w/0.05),int(h/0.05)
cropped_img = o_image[y:y+h, x:x+w]
imageio.imwrite("output.jpg",cropped_img)
This is not yet implemented in NLP or LR right? jus making sure I didn’t miss it. Is it still on the horizon? would be nice!
Working on it… I have a beta out to a few folks who are heavy users.
Here’s a basic demo of it in action.
Still working on a lot of edge cases and integrating directly into NLP (the tools is separate at the moment for the beta testers).
Nate
…and it looks quite well in your movie too.
Idea 1: Set a parameter to crop inside (as shown) or outside (!) the negative.
Idea 2: I can do with a separate plugin. That could help to avoid issues with auto-cropping in cases of negatives having been scanned with a tight crop.
Some film holders (Negative Supply, Dititaliza etc.) will produce waste parts in black and “film rebate white”. Great if auto-crop can handle this too.
Great! And please set a parameter to crop inside or outside (!) the negative.
And an undo option if something goes wrong.
This might be an obvious solution (it’s not perfect) but I tether my DSLR to my iMac and use guides in EOS Utility to make sure every negative is framed up exactly the same, then once I’m in Lightroom I can auto-sync & crop an entire roll at once. There’s hardly any error as long as I’m careful while scanning, which slows me down a little, but saves so much time on the back end. It also lets me choose to keep a little bit of border if I want it.
Did this a while too and found that it took some joy out of rapid scanning. I now mostly crop close enough and use Border Buffer to complement the cropping - all with the same crop locations and BB values. This provides a usable first impression like on a contact sheet. Only the images I want to develop get the definitive cropping.
Would it be possible to get into the beta for this separate tool, or do you already have an adequate pool of testers? I’m already using Negative Lab Pro for converting negatives after pre-processing. I process film of various types, sizes, and conditions, often mixed within a batch.
Hey @nate I’d also love to beta test this separate tool. Let me know if you need anyone else! <3 Thanks for all your hard work!
