NLP 2.4.2 + Lightroom CC release 2015.7
Epson V600 Photo + Silverfast 8.8 DNG
GX680 + Kodak Gold 200 120(I don’t remeber exactly but I might shoot it at ISO 160 as I was also mettering for SX70 meanwhile).
Hi all,
I’m wondering if this is me, worng exposed film (so also me) or just tough material to WB.
Below photo is straight scan from Silverfast, DNG converted to positive, reset and then WB set to Kodak.
I tried with few pics from this roll and I don’t have any pic I would say - yes, that’s it. Rather all gave me feeling to quit (and it’s not about the framming/posing/model/etc but mainly colours).
Here you can find original scans with boarder and try to convert on your own aiming for natural skin.
I’ve had a brief look to your scans. In their current state, the scans are too dark. I’ve never worked with an Epson scanner nor Silverfast, so I cannot comment on how to change the brightness of the scan but the histogram is quite compressed to the left.
Don’t worry for ISO160, which you may have used to shoot the images in the first place. Gold200 can handle overexposure quite well, so that’s definitely not the issue.
I would suggest to rescan the negatives. Someone with more knowledge with Silverfast will hopefully be able to comment on how to do that.
And after this NLP settings I converted it to jpg and add some more contrast and saturation as I always do, because I export always with the “Flat” preset ion NGP.
Thank you,
I will try to scan it again then… I’ve never touch any settings during scanning in SilverFast as I thought it should be as RAW as possible before saving to DNG. I’ll give it a try and share the results
I don’t think that it is a problem with the scanning. It is fine. I think that you only have to reduce the brightness in Negative Lab Pro to give the photo more punch.
This is what I do. Warm white balance, Lab Soft and Lab sharpenning. Reducing the brightness and increasing the contrast.
I agree with Paul74 that there is nothing wrong with the scan of this lovely photo and just needs a little bit of tweaking. Everyone’s monitor and judgment as to correct color balance will differ and be personal. I used the LAB-Standard tone setting, a slight reduction in Brightness, and added some warmth and magenta with the Temp and Tint sliders to get a skin tone that I found appealing and natural.
Testing with your negatives, I found that Lightroom does not choose a NLP profile. Instead, the profile is said to be “missing”. Might be a Silverfast vs. Vuescan issue?
When I select a profile manually, the conversion gets some punch without many further adjustments:
