Lumix S1ii Ngative Lab v2.3 Profile missing
Hello everyone,
I’m new to the community and arrived here because i just recently got NLP and am digitizing with the Panasonic Lumix S1ii. I saw @nate respond to other seekers for profiles in the past and am hoping he might see this or maybe I’ll find out if someone else has any recommendations.
Many thanks!
Sorry for the late reply, but this is now added to the updated profile download. (Look for Panasonic DC-S1M2 v2.3.dcp).
After downloading your profile, you can add this in Lightroom by going to “File > Import Develop Profiles and Presets.”
Please note that any conversions you made while the profile was missing will appear differently once you add the correct profile. When the camera profile is missing, it will still convert, but Lightroom will use it’s own default “Adobe Color” or "Adobe Standard) as the working profile. When v3.1 correctly loaded the camera profile you need, Lightroom updates the image, and now there is a mismatch between the profile applied and the profile used during conversion.
There are two ways you can fix this:
The easiest way is to manually change the camera profile of any affected photos to “Adobe Color” or “Adobe Standard”. When you do this, you will see the image return to the way it looked previously. You can then sync that profile over to all the other images you need (you don’t need to do it individually).
The other thing you can do is to re-covert the image (this time it will do it with the proper profile for your camera). To do this, you can 1) make a virtual copy (if you don’t want to lose your previous edit), 2) Open the image in Negative Lab Pro, go to the “convert” tab and select “reset image”, 3) Then reconvert and re-edit your photo.
