Hi @tmeadow , are you aware of the metadata features included in Negative Lab Pro? I’ve tried to build them to let you do basically what you’ve described (and much more). Below, I’m copy/pasting the information on using metadata in Negative Lab Pro from the v2.1 announcement
Let me know if you have any questions!
Nate
Creator of Negative Lab Pro
1. Custom Metadata (Just for Us Film-Shooters)
Ever since I started shooting more film, it bugged me that there wasn’t a good way to capture the richness of the analog process inside the metadata. Lightroom’s metadata engine is incredible (and fortunately for us, extendable), but by default it is decidedly focused on digital photography workflows. So until now, my workflow has involved separate spreadsheets, complicated 3rd party tools, or simply hoping I can remember everything!
So, with a lot of input from the Private Facebook Group and this very forum, I’ve extended Lightroom’s metadata engine to make it the perfect tool for capturing your analog workflows.
A simple, fast workflow for adding and editing film-centric metadata
Negative Lab Pro extends Lightroom’s own metadata engine with a custom section for film shooters. It’s built right in to Lightroom. In the Library module, just select the dropdown to the left of the “metadata” section, and select “Negative Lab Pro.” When you start add your analog metadata, you get all the time-saving features Lightroom has built-in, like Metadata Presets, Autocomplete, and Selectable Lists of past values used.
Click the video below for demo
Perfectly Organized for Film Shooters
The custom metadata section is divided into 4 editable sections (equipment, shooting, digitizing and development), plus a section of metadata generated from your Negative Lab Pro status and settings. You don’t need to fill in everything, just fill in what you have and what’s important to you.
Sortable and Searchable
Once you’ve added your new metadata, you can use it directly in Lightroom for sorting and searching through your photos. Want to see everything photo you’ve taken using your Hasselblad 500cm, together with Portra 400? No problem!
Non-destructive & Safe For RAW
The original standard metadata is not changed in the original RAW. This is critical, because Lightroom uses the metadata in RAW files (like Camera Model and Lens) to select the corresponding camera and lens profiles to use in rendering, so you don’t want to overwrite this. Instead, the custom metadata is stored non-destructively in Lightroom’s catalog. Then, when you export the RAW to tiff or jpeg, it allows you to generate and store the analog metadata in standard EXIF and IPTC fields.
2. Smarter Exports and “Positive Copies”
Not only does Negative Lab Pro v2.1 extend LR’s metadata, it also adds a custom “export service”, so that you can take advantage of the metadata when you go to share it with other services. You can access this inside Lightroom’s export module by changing “Export to” to “Negative Lab Pro”, or by right-clicking an image and selecting one of the built-in export presets.
Auto Captions
Now that we have all that custom, film-centric metadata, let’s do something smart with how we caption it. In Negative Lab Pro, you can now select what and how you want to caption your photo. This caption is built in to standard metadata fields on export, so it will automatically show when you upload to services like Flickr. It will also copy it to the clipboard, so it’s easy to share on places like Facebook or Reddit, which don’t include metadata.
Write to Standard EXIF Fields
It can automatically write the analog metadata to standard EXIF fields. Which, again, is really nice for both sharing on photo platforms like Flickr and for archiving.
Auto Keyword Generation
It can automatically generate film-centric keywords based on the metadata you input, and write them to standard metadata fields.
Right-Click > Positive Copies
Positive copies are really useful when working with film negatives in Lightroom, especially if you need to make some small tweaks using Lightroom’s normal toolset. Now, you can make positive copies without needing to open up Negative Lab Pro… just right-click on an image (or group of selected images), and go to “Export > NLP - Make Positive Copy”.
Presets for Exporting Files to Flickr, Facebook, Instagram and more…
The presets provide optimized file and metadata setting. You can also call them contextually using the “right-click, export” from the library or develop modules. Below is an example from a file I exported then uploaded to Flickr. The red boxes how the analog info I added was translated into metadata for the Flickr upload.
Full Customization of Export Settings
You can customize any aspect of the export presets and save them as your own. So if you want to change the file naming structure, or output sharpening, or color space… well, have at it!
