My approach to scanning and conversions
I’ve been scanning and converting film negatives for a little over two years now. Through a lot of trial and error my process has evolved substantially, and I’ve finally gotten to a place where I can get consistently good results with Negative Lab Pro, even with challenging negatives and film stocks (I’m looking at you Ektar). I figured I’d share some details about how I approach things today, in case they’re useful for someone either new to scanning and converting negatives, or for someone struggling to get good results.
Camera Scanning Tips
  • Use electronic shutter (or mirror lock-up if on a DSLR) to minimize vibration.
  • Shoot tethered if possible — I use Nikon Camera Control Pro. When tethered you can check for dust and use a rocket blower to clear the negative prior to capture.
  • Manual exposure only — avoid aperture priority.
  • Shutter: Expose to the right. I look at the histogram with a blank frame — pushing the exposure just shy of clipping. When shooting actual negatives, this often looks overexposed by 1–2 stops, but that’s fine as long as the highlights aren’t blown.
  • Use a bubble level like this one to ensure your camera and film are parallel. I’ve had scans that were soft at the edges if things weren’t perfectly aligned.
  • Scan with the emulsion side facing the lens — it’s noticeably sharper that way.
Lightroom Pre-Conversion Steps
Before converting your negatives, there are a few things you should do in Lightroom:
  • Import your RAW files.
  • Flip images horizontally if you scanned emulsion side up.
  • Rotate as needed.
  • Sample the film border to set white balance.
  • Zero out sharpening and color noise reduction.
  • Sync these settings across all your scans.
Now you’re ready to convert.
My Minimalist Approach to Conversion
Before I get into how I convert and edit negatives I want to share why I approach things the way I do. The thing to understand about negative conversion software, be it NLP or anything else, is that it does its best to get to a pleasing image by making assumptions, often by adjusting curves and white balance under the covers. Sometimes it gets it bang on. Sometimes it gets it mostly right, and you can easily make minor corrections to white balance to get to a good image. But when it gets it wrong, things can become very very difficult to correct. The reason is that too many assumptions have already been baked into the RGB curves, and unwinding them can be a frustrating exercise. It’s the inconsistency of the results that was maddening to me for a long time. So my preference these days is to configure NLP to make as few assumptions as possible, and to only get me to a basic starting point where I can then adjust things in Lightroom the way I want. It’s more work, but not excessively so, and I can now get consistently good scans. Here’s how I do it.
Conversion Settings in Negative Lab Pro
Here’s how I configure Negative Lab Pro:
Convert tab:
  • Type: Negative
  • Source: Digital Camera
  • Color Model: Basic
  • Pre-saturation: “3 - Default” (except for Ektar, where I use “1 - Very Low”)
  • Set Border Buffer % with Preview checked
  • Skip Roll Analysis
  • Click Convert
Edit tab (defaults for every image):
  • Tone Profile: Linear Flat
  • WhiteClip: -5
  • BlackClip: -10
This gives a flat image with plenty of room in the RGB curves. You’ll likely see some color casts — we’ll deal with those in Lightroom later.
  • HSL: Natural, Saturation 5
  • Sharpen: Leave as Set
  • Everything else, including white balance temp/tint, should be set to zero
Roll tab:
  • Analysis: “This image only”
Advanced tab:
  • CurvePoints: Auto
  • ColorProcess: Refined
  • ProcessOrder: Color First
  • ColorDensity: Neutral Density
  • ColorMethod: Linear Fixed
  • ToningMethod: Standard Toning
  • ClipMethod: Protect Color Balance
Exporting Positives
Once you’ve converted, select the keepers in Lightroom (flag/star as needed). Crop out the film borders — this is important for color correction when we’re looking at RGB channels later. Then export as 16-bit TIFFs with the ProPhoto RGB color space.
Lightroom Editing Workflow
Here’s where the magic happens.
Step 1: Dust Removal
Use the healing tool with Visualize Spots enabled to clean up any dust.
Step 2: Prep for Color Correction
Temporarily bump global contrast to +30. This makes color casts easier to see. We’ll undo this later.
Step 3: Fix Shadow and Highlight Color Casts Using Curves
This is inspired by Alex Burke’s method — and it works great.
  • Open the Tone Curve panel and switch to RGB channels one at a time.
  • For shadows, drag the bottom-left point (black point) horizontally to the right along the floor, towards the left tail of the histogram, until unwanted shadow color casts disappear.
  • For highlights, drag the top-right point (white point) horizontally to the left along the ceiling, towards the right tail of the histogram, until unwanted highlight color casts disappear.
  • You may only need to pull in the black and white points for a given channel very little. Depending on the image and the film stock you may not need to adjust a given channel at all.
  • You may also need to do a second pass. After adjusting each RGB channel, go back and see if you need to refine each a second time.
Step 4: Adjust Overall Tonality
  • Reset global contrast back to zero.
  • Go back to the Tone Curve panel and select the point curve (with the white circle). Start by pulling in the back point along the floor to the right and then the white point along the ceiling to the left until you have roughly the right contrast you want for the scene.
  • After that, I’ll fine-tune using:
    • The parametric curve for highlights, lights, darks, and shadows
    • Then adjust Exposure, Contrast, Highlights, Shadows, Whites, and Blacks in the Basic panel
    • Optionally add Clarity (+5 to +10) for a bit of punch
Step 5: Optional Final Color Fixes
Still seeing a cast? Try the following:
  • Color Grading tool — target shadows or highlights with complementary colors. Find the opposite color on the color wheel, select that, and gradually increase the saturation. You may need to lower the Blending value to keep the changes isolated to the deeper shadows or brighter highlights.
  • Luminance range masks — isolate shadows or highlights and tweak with Temp, Tint, or Curves
Step 6: Final Touches
  • Global saturation/vibrance tweaks as needed
  • HSL tweaks — I don’t usually touch these much, except for Ektar, where I dial down blue saturation a bit
  • Global white balance for mood or artistic warmth
Step 7: Sharpening
  • Set sharpening to ~50
  • Hold the Alt/Option key while adjusting the masking slider so you avoid sharpening grain in the sky
Wrapping Up
I know this sounds like a lot, but once you get into the rhythm, it’s surprisingly fast — just a few minutes per image. If you have several shots from the same scene, syncing Lightroom settings can save even more time.
If you’ve got a scan that’s been giving you problems, I recommend giving this process a try. I’ve gone back and reprocessed old scans that I had trouble with and I’ve been surprised at how much better they look with this approach.
Questions and comments welcome.
I have found bubble levels a bit of a guessing game. I’ve been using digital levels for many years with great success. Yes, they are more expensive than a bubble level, but if you are going to do this hundreds, if not thousands, of times, it makes sense to upgrade your gear. Here is one that even includes a bubble level. Digital Electronic Level and Angle Gauge, Angle Finder with Bubble Level and Magnetic Base, High Contrast Display for All Environment, Measuring Tool for Carpentry, Building, Automobile, Masonry: Amazon.com: Tools & Home Improvement
I have found the typical bubble level to be woefully inadequate for getting the camera sensor parallel with the film plane. I have also found that the type of digital angle cube as mgilvey mentioned to be far better for leveling and setting angles than all of the “precision” methods machinists use. I’ve use the digital angle cube for “leveling” my camera body with the film plane. If I were to use a bubble level, it would have to be a high precision type, such as machinists use for “leveling” machine tools. But both the bubble level and digital angle cube rely on an assumption that whatever part of the camera body the measuring device is placed on is parallel with the camera sensor.
More recently was introduced to the “mirror method”, which I have found to be quite excellent and dead simple. I haven’t yet compared the digital angle cube with the mirror method, but the mirror method is so simple, I’m not sure there is a point.
For what it’s worth I use the mirror method as well, it is the only direct way of establishing alignment with the sensor, still it’s a debate that seems to endure.
I’m puzzled about the question of ‘scans’ being sharper when the emulsion is facing up, I don’t believe it frankly. Doesn’t seem to matter with my 6,300 ppi Imacon scanner and not with this 61MP Sony capture either:
Are you adjusting the shutter speed for each frame, or are you using the same for the roll based on what you measured on the blank frame?
A mirror works fine for aligning the planes. Just put the mirror on your light table and when the sensor appears exactly centered in the mirror image, youre done
