Negative Lab Pro v3.1 - New Color Processing, Support for Slide Film, Improved Batch Editing, and More
@nate, I am setting up a brand new iMac and would prefer not installing Rosetta on it. However, until I have Negative Lab Pro up and running I cannot be complete; this is one of the most important apps for me.
Any idea how long before an Apple Silicon version is available, even if it’s a beta?
Unfortunately, I will need to ship the old Mac to Apple in the next week or so.
@tadtadd , I understand your want to run the new Mac without Rosetta2 for whatever your reason might be.
What I did to prepare for Rosetta free use is this
  • Create e.g. three volumes on the new computer
    • One volume (A) as an archive for the photos and software installers
    • One volume (B) for macOS without Rosetta 2
    • One volume (C) for macOS with Rosetta 2
  • Copy the "stuff* that should be on (A) from the old Mac to an external volume
  • Install macOS on (B) and migrate user(s) without the "stuff*
    • the new Mac will now work from (B)
  • Copy “stuff” from the external drive to (A)
  • Reconnect Lightroom to the photos on (A)
  • Install macOS on (C) and migrate user(s) from (B)
    • the new Mac will now work from (C) and you can install NLP and Rosetta too
    • once you can get everything universal or native, boot from (B), get things from (C) as needed and remove (C)
Keeping photos and installers separate speeds up the migration and helps to manage drive space. I use Carbon Copy Cloner to move things to and from separate volumes. CCC can copy with checksum verification. It takes some additional time and provides data integrity.
Applying the concept listed above, the Mac I use for testing has a shared volume (A) and one volume each for macOS 11, 12, 13, 14, 15…and I just deleted the volume for Sequoia with Rosetta. I also use (A) for apps that can live in such conditions. Caveat: APFS has evolved over the last few years and one is well advised to not use disk utility too liberally in recovery mode because it has the potential to mess things up.
That would be a bold move! Thanks for putting together a solid punch list.
For now, I’ll sit tight for a few days and see what other things I start finding as I move into the new machine. Already TurboTax is a Rosetta offender: I’ll just do my taxes on the old machine before sending it off.
If I find too many other things that need Rosetta I’ll just have to bite the bullet and install it. If I can still avoid it though, and NLP takes a few more weeks, I suspect I can hang back until the release before doing negative scanning, though that will be a challenge!
It’s easier to stop shooting in the dead of winter, but springtime is coming fast.
Looking forward to the release not only because of Rosetta, but also because I face the same Lightroom issue that has forced many of us to revert to an older version of LR–that should be fixed in the new release.
I have noticed that the multipass option can’t be saved in 3.1. Am I doing something wrong?
I have been using the 3.1 beta for slide processing over the last few weeks and it is an amazing improvement. I have slides going back to the 1950s, some very badly discolored and NLP 3.1 has in many cases made miraculous recoveries. I am rescanning all my hundreds of slides with the beta 3.1. (All this is on a Windows machine). BRAVO Nate!
Here’s an example.
The photo was taken in 1956 and the slide has a heavy cast as can be seen at left above. Framed between to layers of fairly thick glass, the slide has been well protected, but some changes that look like they have crept inwards from the edges show up. I remember the slide being underexposed and some additional adjustments could improve the overall appearance. With all the details hidden in the shadows, the slide could probably profit from exposure bracketing HDR.
Can’t say what the film was, I’d have to open the frame for that - and I’m not inclined to do so.
Hello,Nate.
Could you tell me the approximate release date for the full version?
I am also waiting :smiling_face_with_tear: … so long…
Wedding photographer here… just wanted to say having the Match feature back with the 3.1 beta has been amazing. I’ll often have several images under identical conditions that the match feature is nailing for consistency. Cheers!
scanning my first roll with the beta, the match feature is indeed so soo good! also the problem with the nil-value thing for intel macs seems to be worlds better. thanks so much!!
Hello Nate,
Like others having a great results so far with the “positive” feature so far in the beta (windows b4). No problems so far from a functionality perspective. Have noticed conversions are often a bit “bright” but still working through settings. Mostly Kodachrome slides from the early 70’s - lots of fading variation including the typical purple shift. So far so good with NLP giving me a fantastic starting place - so much faster than my lightroom-photoshop workflow.
Will play with the negative features soon.
Also like others - really curious if you have any updates on the product release - e.g. timing.
Thanks again for all of the hard work making these great improvements to the product!
Maybe I’m missing the obvious… but where do I download the latest version? Also, do you also send out emails to registered users to announce new updates? I just noticed I am still on 3.0.2, the version that was actual when I bought the licence :upside_down_face:
I think you’ll find that 3.0.2 is the latest version (still) though there is a beta version of v3.1 available for testing. Development was severely affected by two hurricanes in Florida.
Searching the forum, you’ll find a link to a beta version of NLP 3.1
I’ve worked with it for a while now and it works almost without issues.
Due to other problems with Lightroom, I’ve downgraded to Lr 13.4.
I finally jumped in to the 3.1 beta a few days ago and found it is instantly improving the colour balance I am getting on the slides I was trying to manually colour grade in lightroom with much time and effort. It is making a big difference to me.
I am using version 11 of lightroom classic on windows 10.
This evening though, I have found that I am coming up against an issue with negatives I have already converted when I try to use the multi pass setting. When I switch to multi pass on a converted negative in the engine settings menu, the image instantly changes, usually getting slightly brighter, but when I then try to move the sliders in the edit tab, the sliders have no effect on the image. If I reset or reconvert the negative using multi pass the same is true, the sliders are ineffective in changing the image. The sliders only start to work again when I go back to single pass. I just can’t seem to get multi pass to work for me. Perhaps there is some kind of glitch my end. Has anyone else found similar or it is just me.
A bit of further experimenting and it’s possible that I am able to do a multi pass on a positive image, rather than a negative one. The default is always set to single pass the first time, but then i set it to multi pass. But no… I’m thinking, an additional pass isn’t actually being done by simply changing the setting in the engine tab is it. But the sliders work, with it set like this, which is different. But no, I don’t think I have actually had a successful multi pass result yet.
Here’s another positive conversion done by NLP 3.1 Beta:
The original slide (captured on the left) is more than 30 years old but has mostly kept its quality even though I had stored it rather sloppily. NLP’s conversion produces a more moody image with slightly higher contrast that makes the lantern look more blown, makes the grain of the wood more visible and deepens shadows. I’d want to remove some of the magenta off the floor and the rest of the image though.
Can’t help wondering how you produced the ‘scan’ on the left, a film scanner perhaps? It looks fine to me, much better than the one on the right, but then I haven’t seen the original.
That’s the rig → Let's see your DSLR film scanning setup! - #336 by Digitizer
Oh, that was just a capture and a conversion without additional adjustments.
In general, NLP converted slides have more punch (and possibly colour shifts), but nothing to worry about. I consider conversions as starting points, and if I’m unhappy with them and the picture is worth it, I’ll edit, preferrably on a 16 bit TIFF positive copy.
Ah yes, your setup is an elegantly simple solution, very solid I imagine. Picture shows it in 120 stitching mode presumably.
Pictures taken with Mamiya 645 cameras appear to be in portrait orientation on the film strip, because film is transported vertically. That is why the camera is installed like it is.
