When I remove a converted image (the raw file, not a TIFF copy) from Lightroom, restart Lightroom and sync the folder that contains the file that has been converted and removed, the file has lost the conversion.
Even though the .xmp sidecar was saved before removing the file from Lr, the conversion was lost.
This basically means that all info about the conversion (including metadata) resides solely in Lr’s catalog and is not exported to the sidecar file.
Is this
a) correct,
b) intended and
c) can we do anything in order to preserve conversions under these circumstances?
This is inherent to the principles of Lr: everything you do is written to the Lrcat file. However you can modify this in the Lr Catalog Settings and tck the 3 upper boxes.
Hoping it helps
A. Yes, this is correct. When you remove a photo from the catalog, it loses any catalog-specific metadata associated with the photo.
B. I don’t have a choice, unfortunately. That’s just the way it works in the LR SDK. Any plugin specific metadata is associated with the photo via the catalog.
C. If you need to move or share files and keep all this metadata for further editing, the best way to do that is through exporting/importing as a Lightroom Catalog. Just select the images, and go to “File > Export as a Catalog”. Then wherever you need to move it to, use “FIle > Import From Another Catalog.”
