Ask: It would be great to add an option for removing the original converted negative when a positive TIFF is made. (That is in additional to stacking/putting in a different directory, add an option to replace the original file entirely).
Reasons: When we use a high resolution scanner to scan the negatives, the size of the DNG file can be huge (~500MBs). If we make a positive copy, the size per file goes to 1GB. However, in most cases it doesn’t make too much sense to retain the original file as we can do all the adjustments in the positive copy. It could be an hassle to manually select all the DNG files and remove it from Lightroom and hard drive.
