Hi all, I’m having a lot of trouble with color noise when editing my negative scans with Lightroom v13.0.2 and was hoping someone might know something I don’t that could help me fix this.
I am using NLP v2.4.2, and scanning with a Nikon Coolscan V using Vuescan 9. I scan all negatives as 48-bit raw files and don’t touch them further in Vuescan. After scanning, I take my raw files and import them into lightroom, update the metadata for a Silverfast/Vuescan raw file, and then convert the images one by one with NLP.
Here is where the issue begins. Conversion with NLP is completely successful. I usually leave sharpening in NLP’s window to “off” (please correct me if I should not be doing this). However, the inverted negative is often filled with color noise. Historically, I have used the manual noise reduction in Lightroom’s “Detail” panel, which has the unfortunate side effect of removing a lot of sharpness and detail.
However today I discovered something odd: if I toggle off the Detail panel with the small eye icon, all the noise disappears completely and I am left only with the natural grain of the negative. See this gif for exactly what I am talking about: link to gif (too large to paste inline)
I’m not sure what is causing this nor how to fix it. As far as I know the little eye toggle is temporary and there is no way to make it stay “off” all the time.
Has anyone had a similar issue, or does anyone have any guesses as to how I might fix it? Now, seeing my photos with the noise toggled off, I’m keen to get rid of it in all of them as I can now see how big of an impact it has.
Thanks very much in advance for any help or insight you all may be able to provide. I greatly appreciate it.
