I’m scanning using a Flextight X1 and am really happy in general, but quite often I find the highlights are clipped in the conversion (although the information is present in the scan itself). To rectify this I adjust the whiteclip parameter to something like -2 or -3, very rarely needs more than that. This works fine but each time I adjust that parameter, the white balance of the conversion shifts fairly dramatically, usually between green and magenta. So perhaps it’ll be fine at 0, goes magenta at -1, green at -2 and so on. I then find it difficult to compensate for this shift using the white balance adjustment sliders, so the workflow is quite awkward as a result.
I’m wondering if I’m doing something wrong here or if there’s a way to avoid these quite dramatic WB shifts when adjusting clipping?
