I’m getting good results bulk scanning roll with Roll analysis and using Auto-neutral setting in white balance. I think there’s still almost always too much magenta so I have to adjust the white balance for each frame.
Would be great if you could set the white balance for example to Auto-neutral minus two clicks of magenta and then sync it for the whole roll. Now if I click few steps tint towards green, it is gonna set a custom white balance, and when I sync it. It will make the same white balance for each frame, instead of using Auto-neutral plus the adjustment.
