Hi Nate, thanks for your excellent work. I would like to know if it would possible to implement a control in order to adjust the color curves?
It is already possible to adjust the color curves in Negative Lab Pro… this is what is happening when you use the RGB/CMY sliders.
These sliders are making very precise adjustments to the color curves themselves.
The “mids” sliders are controlling a gamma curve in the midtones (without changing the black point or white point).
The “highs” sliders are controlling the white points within the color curves.
The “lows” are controlling the black points within the color curves.
Creator of Negative Lab Pro
