Lol to be fair it’s one of the more affordable medium format cameras out there
the N II is quite a bit more but only has one or two new features for twice the $
The Nikon F6 does this as well. It prints the exposure information in the small space on the film rebate, between the frames (not at the top or bottom).
Hey Nate and all. Just wondering if there is an estimated date release for the next version of NLP. I’m looking forward to your implementation of the exif data for camera make, model, film, etc. Have been slowly re-processing all my RAW scans with NLP and Lens Tagger but would love to do it all in one step.
Hi @patofot,
The custom metadata feature has now been added to Negative Lab Pro v2.1.
Thanks to @tonyjuliano and everyone else in this thread for their input.
Custom Metadata (Just for Us Film-Shooters)
A simple, fast workflow for adding and editing film-centric metadata
Negative Lab Pro extends Lightroom’s own metadata engine with a custom section for film shooters. It’s built right in to Lightroom. In the Library module, just select the dropdown to the left of the “metadata” section, and select “Negative Lab Pro.” When you start add your analog metadata, you get all the time-saving features Lightroom has built-in, like Metadata Presets, Autocomplete, and Selectable Lists of past values used.
Click the video below for demo
Perfectly Organized for Film Shooters
The custom metadata section is divided into 4 editable sections (equipment, shooting, digitizing and development), plus a section of metadata generated from your Negative Lab Pro status and settings. You don’t need to fill in everything, just fill in what you have and what’s important to you.
Sortable and Searchable
Once you’ve added your new metadata, you can use it directly in Lightroom for sorting and searching through your photos. Want to see everything photo you’ve taken using your Hasselblad 500cm, together with Portra 400? No problem!
Non-destructive & Safe For RAW
The original standard metadata is not changed in the original RAW. This is critical, because Lightroom uses the metadata in RAW files (like Camera Model and Lens) to select the corresponding camera and lens profiles to use in rendering, so you don’t want to overwrite this. Instead, the custom metadata is stored non-destructively in Lightroom’s catalog. Then, when you export the RAW to tiff or jpeg, it allows you to generate and store the analog metadata in standard EXIF and IPTC fields.
2. Smarter Exports and “Positive Copies”
Not only does Negative Lab Pro v2.1 extend LR’s metadata, it also adds a custom “export service”, so that you can take advantage of the metadata when you go to share it with other services. You can access this inside Lightroom’s export module by changing “Export to” to “Negative Lab Pro”, or by right-clicking an image and selecting one of the built-in export presets.
Auto Captions
Now that we have all that custom, film-centric metadata, let’s do something smart with how we caption it. In Negative Lab Pro, you can now select what and how you want to caption your photo. This caption is built in to standard metadata fields on export, so it will automatically show when you upload to services like Flickr. It will also copy it to the clipboard, so it’s easy to share on places like Facebook or Reddit, which don’t include metadata.
Write to Standard EXIF Fields
It can automatically write the analog metadata to standard EXIF fields. Which, again, is really nice for both sharing on photo platforms like Flickr and for archiving.
Auto Keyword Generation
It can automatically generate film-centric keywords based on the metadata you input, and write them to standard metadata fields.
Right-Click > Positive Copies
Positive copies are really useful when working with film negatives in Lightroom, especially if you need to make some small tweaks using Lightroom’s normal toolset. Now, you can make positive copies without needing to open up Negative Lab Pro… just right-click on an image (or group of selected images), and go to “Export > NLP - Make Positive Copy”.
Presets for Exporting Files to Flickr, Facebook, Instagram and more…
The presets provide optimized file and metadata setting. You can also call them contextually using the “right-click, export” from the library or develop modules. Below is an example from a file I exported then uploaded to Flickr. The red boxes how the analog info I added was translated into metadata for the Flickr upload.
Full Customization of Export Settings
You can customize any aspect of the export presets and save them as your own. So if you want to change the file naming structure, or output sharpening, or color space… well, have at it!
You can read about it here: Negative Lab Pro v2.1 - Film Metadata, Clipping Control, and Much More
Cheers!
Creator of Negative Lab Pro
This is fantastic, Nate. As I mentioned elsewhere, I use a utility very similar to LensTagger called AnalogEXIF - its’ essentially the same thing but I’ve loved the way it organizes camera/lens selection combinations and once setup is just a single click. I’m still playing with getting close to this ease with the LR metadata fields and it’s not too far off, but not quite as magic yet at least in terms of steps.
But all that said, the fields themselves are fantastic, as are the export options.
What would REALLY make me happy (perhaps elated) personally is if those metadata write options could be included as something like an “NLP Metadata” in the Post-Processing Actions of the export module. This would allow those to be used for all other existing exports, as well as (most important to me) publishing services; I use several publishing services, especially for Flickr so that a) my changes to my images can be easily updated there whenever I like, but also b) in order to do it otherwise I have to continue generating TIFF or JPG files separately to either be discarded once the upload is complete, or kept for continuity on my personal storage, which would be preferred but adds up quick. With the publishing service option, it’s only the RAW, or source TIFF, that’s resident on my hardware and the published export version is gone, yet still linked in the service.
Long story short - it’d be rad to, as per usual publish service, retain just the raw but be able to add the NLP metadata changes for Flickr and other sites during the publish. That’d be gravy.
I would also be very much interested in a feature where the film metadata would be included in WordPress, Flickr, or other publishing services.
I don’t believe I’m able to link in to the publishing services plugins themselves (for instance, the Flickr plugin in Lightroom), BUT, I have included a custom export setting for Flickr, which should produce files with the film metadata that are appropriated formatted for uploading to Flickr.
Flickr is very friendly to showcasing metadata, so using this feature in Negative Lab Pro is really helpful!
Wordpress is not very friendly to metadata, as I recall. And of course, Facebook and Instagram strip metadata on upload.
You can learn more about how to use the metadata features in Negative Lab Pro here:
Cheers!
I’ve built functionality for this into wordpress using ACF. In my case i have picklists in ACF to set the metadata for each image in the WP Media Library. If i take the time to cut everything over to the NLP LR Metadata fields i could look into auto-populating the ACF fields on upload.
This works pretty well for me but it is a bit of work just due to adding the metadata manually in WP.
I’ve got a Gutenberg block that displays the image and metadata, so after populating the metadata fields i’m really just posting an image in the block editor. I recently added content credential support to this too - something else that isn’t currently present in wordpress.
