Hi All. This thread is like a who’s who of camera scanning! Hi SSelvidge and nice to meet you Vlad!
I use the Sigma 105mm f2.8 DG DN Macro Art on a Sony a7RIV and the Valoi easy35.
Verdict: It is spectacularly sharp in the center and very good even in the extreme corners. Highly recommend.
I personally or with the help of friends directly tested the following setups:
- Nikon D850 with AF-D 60mm
- Canon R5 with AF-D 60mm with AF-G to RF adapter
- Nikon D850 with AI-S 55mm
- Nikon D850 with Sigma 70mm 2.8 DG EX Macro
- Canon R5 with RF 100mm Macro
- Canon R5 with Leica Macro-Elmarit-R 60mm with 1:1 Leica extention tube and Leica R to Canon RF adapter
- Nikon Coolscan 5000 ED
- Epson Perfection V750 Pro
- Nikon Z7ii with Nikon Z 105mm Macro
- Noritsu LS-600
I highly recommend the Sigma 105mm.It performs excellent in corner to corner sharpness, and the autofocus is reliable enough on the sony + sigma that I regularly use it, and only rarely switch to manual focus if a certain roll or negative is particularly difficult to get focus on the grain.
I did not compare it to the 70mm DG DN Art directly, as there are enough references online that says the 105mm outperforms the 70mm, so I did not bother.
As a second choice, the Nikon D850 gave me very nice scans with zero noise and a bit more of a softness in the grain that made for pleasant photos, the Nikon D850 with AF-D 60mm is my second choice. It’s great value for the money. But, I always have to manual focus this setup, which became bothersome.
The Sony + Sigma easily outperforms the Coolscan and Epson hands down. The Noritsu is incredible, you get comparable linear resolution from a 24MPix image as you do from the 60MPix. It’s a very contrasty scan in comparison though, it doesn’t have the tonality of the modern sensors.
As for the Rodenstock, the 2X lens is the wrong lens to compare, it does not perform well at 1:1 magnification. The 1X will outperform these lenses in corner sharpness as reported on the facebook group “digitizing film with a digital camera”. I did try enlarger lenses too, but this is a painfully DIY setup with adapters and helicoils and copystands. Yuck.
easy35 is the most convenient and fun way to scan negatives. Copy stands suck to use, I avoid them.
A word of warning: We chase sharpness because its easy to measure, but sharpness isn’t everything, color reproduction and ease of use is also important. For example, I have seen no discenrable benefit moving from 45MPix to 60MPix (its <15% better linear resolution) but my file sizes have increased. None of these setups, not even the Rodenstock, will resolve down to the grain - I have put my macro lens on a 5:1 bellows and compared the 5x optical magnification of the image, and there’s much more fine grain detail in the 5x optical magnification. That being said, it becomes an academic exercise to truly capture every silver grain.
