Camera or Scanning issue?
On my 120 color scans it appears that the edges are more properly exposed, and then rest of the negative is over. Is this an issue with my film camera or a scanning issue? Any suggestions?
Well, for the specific sample you posted it looks to me as if the red-circled portion is under-exposed and the rest of the photo is better exposed. Anyhow, there could be a number of reasons for systematic uneven tonal rendition. One would need to know a lot more about your set-up and procedures for trying to identify what’s going on.
Check if lightroom is activating a random profile with vignetting on.
I had this issue for a long time until I realize this was messing with my scans.
My hunch would be that this due to unevenness in the scanning backlight. It could be brighter near the edge. The film rebate looks a little pale outside the circled area, and darker near it. This would suggest to me that this is happening in the scan and not on the negative. Since the falloff looks linear and not circular, I’d wager it’s the backlight and not the lens. But just semi educated guesses based on the image.
You could try taking a photo without the film and fiddle with curves/contrast to you see if the scan has a brightness difference accross the frame without the film.
A. If it was your film camera.
I think that you would see this by inspecting the actual negatives together on a larger light box, preferably one large enough to show the entire film. To me it seems unlikely but it is hard to tell from just one part of a single frame.
B. If it is your scanning setup
Again, difficult to tell from seeing one part of a single frame but photographing without a negative in position and exposing to roughly give a mid tone would be helpful, use the same aperture on your ‘scanning’ lens.
Even better photograph with a piece of blank unexposed colour negative film and do the same. Viewing the resulting ‘scan’ and increasing the contrast will highlight any potential problems.
Yeah so I just took a photo of my light source and this appears to be the problem. Anyone have any DSLR scanning setup recs for 645?
Not quite yet:
  • If the light panel is the cause, turning the panel will show the brighter areas according to the rotation.
  • If the unevenness is caused by surroundings or reflection, turning the panel will not change the brighter parts location.
  • If turning the panel creates yet another pattern, it’s a combination of both the panel and the surroundings/reflections.
In my tests, I noticed that wearing a white t-shirt is not a good idea. It throws light back onto the negative. Same for pale hands near the lens. Even in complete darkness, a white wall can cause unwanted stray light. And last but not least, the ceiling can add stray light that casts a diffuse shadow of the camera onto the negative.
My negatives are mostly 645 and I use a large Kaiser Plano as backlight. I’ve tried iPads too, but they need either diffusion or bigger distance or the rgb pattern will show.
It can be light leaking in from the light itself and into your lens. Make sure to tape/blackout off the unexposed portion of the light if you have it unexposed. I don’t have the full details of your setup, so you might be already doing this, but thought to mention it just in case. I had a cinelight in the past which is bigger than the negative so the unexposed light would flare my lens up on the edges like this which resulted in a darker scan on the edges
