Sometimes afte a batch conversion, when I open up the negative lab pro plugin, I am prompted with the option to convert the negatives. though they are allready converted. I cannot edit them, or reset them.
It’s particularly enoying, since when I reset the images via Lightroom, I have to crop each one of them again…
Hi @DOS9570 ,
Hmm, that shouldn’t happen.
Can you walk me through more specifically the exact steps I could to try to recreate this error?
For instance:
- Import fresh set of negatives
- Select all the negatives
- Open Negative Lab Pro and convert the negatives.
- Hit “apply” to close out Negative Lab Pro
- Unselect the group of negatives (Command + D) and select a single negative.
- Open Negative Lab Pro on that single negative
The more detail you can provide the better!
To be honest I can’t.
It happens from time to time, but it’s hard to predict.
