I usually convert all 36-37 shots at once, and it takes several minutes to finish, but during the conversion, I cannot do anything else in the Lightroom, because of the dialogue that counts the converted negatives. It would be helpful, if you can put this in the background, so I can continue working, instead just waiting.
I wish I could do this but it is not possible with the way that the SDK in Lightroom is setup and how Negative Lab Pro is built.
Oh ok, I thought that might be the reason. Thanks for confirming!
If i could join in - before upgrading i had a 343 scanner. It was so slow I used to set up the scan and go and have a coffee. So all my scanning was done in the morning !! Now i have a faster scanner and miss the coffee.
