Recently, I have been having issues with converting negative scans to positive images using Negative Lab Pro. I have had several images in which I have normally scanned using the Epson Scan 2 and gotten a good negative. Then when using Negative Lab Pro, the image becomes fade or just lighter and cannot be fixed with changing settings. Other times the image becomes completely yellow.
Hey there & welcome!
Do you mind sharing a scanned negative to see the effect in action?
This is usually the most helpful way for others to judge where things might have gone wrong.
– Chris
Below, I have attached the scanned negative!
