Hi there,
After converting an image I usually move the Edit sliders with the keyboard (often shift+up or down to increase or decrease by 5). In the latest beta something seems to be wrong as for example on the Darks slider I can’t seem to go past 30 with the up key, but the max is 50, which I can reach if I use the mouse instead. Same thing for the Blacks slider. Also the Brightness slider goes to a maximum of 30/-30 when moved with the mouse, but with the keyboard, even if the slider is at the extreme and the position doesn’t change anymore, you can increase or decrease the brightness up to 50/-50.
I’m sure this one is an easy fix for Nate
My setup:
- Windows 10
- Lightroom 9.3
- NLP 2.1.8
Regards,
David
