I’m having an issue with saving roll analysis’s in NLP. Essentially, when I try and do a roll analysis it appears to work at first, but when then closing out of NLP and entering back in it ‘resets’ the photo to pre-analysis and the analysis is nowhere to be found in the dropdown (see below).
There are rolls I’ve converted that seem to have a saved roll analysis and show a Roll ID in the metadata, but for any that I’m trying to do a new analysis for I’m unable to. For the ones that do have an analysis I’m also only able to see that 1 analysis in its dropdown.
I’m on an M4 Mac with MacOS 15.6.1. I was able to find in my / Users / { username} / Library / Application Support / Negative Lab Pro / that there is actually no Rolls subfolder, only presets (had a hard time finding this at first but was accidentally looking in my overall Library rather than user Library, in case anybody saw this post pre-edit).
I have the same issue and previously wrote asking for help, but without success Hopefully there is someone out there with a solution? I have checked the permissions and it still isn’t saving correctly. Any advice would be appreciated Thanks in advance!
I was actually able to finally resolve this by changing the permissions on the Negative Lab Pro folder within Library / Application Support to below (specifically changing staff)
I made the same change for the Profiles folder within this and am finally able to save custom profiles as well
that has been happening for me randomly and I am yet not sure why. there might be a pattern: it only happens when I select all photos of the roll once again and re-open negative lab pro
its actually pretty scary, as I take a long time to edit it sometimes just dissapears, throwing off colors and everything
one fix: select all photos, hit uncovert (do NOT reset), and convert them again.
