LR 6.14 / Win11Pro 25H2 / NLP 3.1.1: no menu for entering conversion parameters
I installed NLP and tested it briefly. Everything worked without any problems.
I tried a few color negatives and everything was fine. Then I tried a black-and-white negative, and again, everything was fine.
But now, when I select a photo and launch NLP, the window for setting parameters doesn’t appear at all. The color negative immediately turns into a black-and-white negative, but no menu for entering settings appears.
I tried reinstalling NLP, but the result is still the same. Please advise me on how to proceed…
Thank you.
Problem solved. It was my own silly mistake. I just realized that the settings window was displayed on my second monitor. But since that monitor wasn’t turned on, the window wasn’t visible anywhere. There was no problem after all, and everything is running smoothly again, just like before… I apologize and would appreciate it if you could delete this unnecessary thread…
