PLEASE READ BEFORE POSTING. If something doesn’t go as expected with Negative Lab Pro version 2.1, please do the following.
First, please look through Common Issues and Solutions and search this forum (using the magnifying glass icon to the top) to see if there is already a solution.
If your issue is not addressed above, please provide as much information about your issue as possible.
You should include the following when reporting an issue:
- Your operation system
- Your version of Lightroom
- Your version of Negative Lab Pro
- Steps to take to recreate your issue
Thanks!
UPDATE: The following issues are addressed in v2.1.2, which is available to download now
"'Profile Missing Issue’
Fixed in v2.1.2
Even if the profile is correctly available, it sometimes shows a “profile missing” warning in Lightroom. This can happen when working with certain Silverfast files (it will try to load the camera profile instead of the scanner profile) or when you change the “source” to Vuescan/SF when working on a digital camera scan.
(It’s also possible if you see a Profile Missing error, that you either need to correctly add the camera profiles to Lightroom, or make photos from that scanner model compatible. You can ensure compatibility for Vuescan and Silverfast DNGs by going to “File > Plugin Extras > Update Vuescan/Silverfast DNGs” and following the prompts. After doing this, it should add Negative Lab profile to list and automatically select it. If it is STILL missing after doing this, make sure you are using a 48bit dng (not 64bit) AND re-check to make sure you have the camera profiles in the proper location. If the camera profiles are not in the right folder, you need to move them to the right folder and restart Lightroom.)
TIFF Prep Tool is overwriting existing EXIF Data
Fixed in v2.1.2
TIFF Prep Tool will not work if folder path to plugin contains spaces
Fixed in v2.1.2
ERROR: OUT OF LICENSES - This key has been used too many times.
Fixed in v2.1.2 - but if you receive the error, you will still need to email me after upgrading
If a very specific set of conditions occur when trying to register, license submission will throw an error, causing future attempts to fail to register but still increment your uses each time you try. If this happens to you, please email me at nate@natephotographic.com.
