I downgraded to LR Classic 9.2 but the issue still persists. Hope you can find a solution with that file I sent you.
Best,
Dixon
Best,
Dixon
Hi Dixon,
Thanks, that’s really helpful to know.
I tried with the file you sent, but I couldn’t replicate the issue. Everything worked as it should. I’ve had a few other users who have experienced the same issue as you, so you are not alone!
Until I can replicate it though, I really don’t know what could be causing this or how to fix.
Ah, thanks for trying! I have another more recent LR catalog I’ve been importing scans to and they work totally fine. My main catalog is older (from LR 4 or so) so hopefully it’s a LR bug that gets fixed because I can’t even begin to imagine rebuilding it.
Hi!
I have a little unstable problem.
Windows 10
Lightroom Classic v9.2.1
What do you make of this?
Reinstall NLP?
I DSLR scan my negs, import them to en external HD, then do my editing offline form the HD. Has worked great with NLP until updating to 2.2. Now I can’t run NLP unless I am connected to the external HD. I always import with 1:1 and Smart Previews.
To test, I plugged in my HD, and could run NLP on one of the photos in question. I then told LR to build 1:1 and Smart previews just to be sure. I then ejected HD, and could not run NLP ion them. It asks for the original file. I also un-converted a photo I had previously ran through NLP while offline. Tried to run NLP on it, and got the same error message. See below:
ERROR: Could not access original photo for analysis.
Photo Location:
/Volumes/PHOTO DRIVE/Pictures/2015/2015-12/120 Film/120-092-2.DNG
If your photos are on a portable or networked drive, make sure they are connected.
Hello there
Missing profiles…
I saw this problem on the web but without find a solution
I was attempting to fix some color-cast issues I’ve been having with my scans (Hasselblad H6D 100pxl) and I realized my profiles were missing.
I attempting to reformat/redownload nlp and lightroom but still nothing happen
My current scans read Missing Profile
I wanted to see if anyone has had similar profile missing issues and how you resolved them. Thank you!
I tried to post my problem on facebook but still no answers…
Best
Yohann
Hi @Truminski, there seems to be no profile for your camera back.
I can’t see any profile in Adobe’s Camera RAW collection that @nate could modify accordingly.
Thanks for your answer @Digitizer hope that @nate could help me one day ![]()
Hi @Truminski
If you can send me a sample scan to nate@natephotographic.com, I should be able to add support for it (or at the very least, recommend a workaround).
Thank you very much @nate for your help I just sending to you.
Hope we could find a solution.
My best
