Getting an error message when converting a negative:
Have traced it to following sequence:
- Open NLP (either using Hotkey or through LR menues)
- On the ‘Convert’ tab input ‘Border Buffer’ to any value, press ‘Tab’ to select ‘Convert Negatives’ button
- Press ‘Enter’
Get error above.
If I press ‘Space’ instead, no error.
If I click on ‘Convert Negatives’ button I don’t get an error either.
So something with ‘Enter’ seem to be causing the problem. File/folder access is OK since it works fine with other input alternatives.
Running v.2.3 on Windows 10
