I’m having the same issue, but I’m running macOS 14.5 (apparently I didn’t know there was an update lol) on an Intel MacBook Pro and using Lightroom 13.5.1 and NLP v2.3. The issue was mostly happening when batch processing a whole roll, but occasionally crashed when I was converting a single negative.
As soon as I downgraded Lightroom to 13.4, the problem disappeared.
I have Apple M1 Max on a Mac Studio. From all I am reading from you guys sounds like I would be safe to continue & upgrade my operating system to Mac Sonoma 14.6.1. I am currently running LR 13.5.1.
I am not that brave so does anyone else have M1 Max and completed the upgrade?
Any help always appreciated.
Nate:
I’m still having an issue after upgrading to MacOS Sequoia (15.0) on my iMac Pro, with LR Classic 13.5.1 and NLP 3.0.2.
However it seems I can convert 3 or 4 negatives at a time, but no more, without issue. That’s a little better than doing them one by one, which was my workaround before with 14.6.1…
I was having the same issue with an intel mac. I upgraded to OS 15.0.1 and had the same issue. With a Lightroom version change to 13.4, it seems to have gone away
I’ve had this same issue intermittently on my M1 Pro MacBook Pro Running Sonoma 14.5
I found that the error was thrown in a few scenarios for me.
When selecting multiple RAW files to convert, I noticed it would throw it if one of those images was a DNG (I converted one, forgot about it, and it sat in that roll) NLP seemed to not open when the DNG was selected in the group of RAW
Also If I converted let’s say 2 full rolls. and each roll had a “first image” that I didn’t convert. When I batch selected the whole lot of 2 rolls (including the 2 non-converted images) This error popped up.
in both cases, it seemed the only way to fix this was to restart Lightroom Classic, and then select the multiple images I was trying to open NLP for, but NOT select the DNG in case 1 or the un-converted images in case 2.
Using DNG created from Vuescan and edited with NLP 2.x 2 years ago. No change if I try to reset all settings. Got the error if I try to edit only one or if I try several with the new roll functionality.
Any news on this one? I tried an untouched raw (not negative) and the conversion works fine. But if I try a DNG from Vuescan earlier edit with NLP 2.x I’m not able to edit…
I have this same issue, ran into it today. After encountering the problem, I upgraded to NLP v3.0.2. but the problem persists. I have MacOS 14.6.1 and LRC 13.5.1. I am trying to scan a Silverfast 9 DNG and things worked fine with this workflow until today, must have been the Sonoma or the LRC update that messed things up. The last batch of negatives I scanned successfully was on August 1.
Except that the problem remains. It seems to happen at random, one conversion will crash and the next one will be OK. I am scanning a roll at a time to DNGs and then converting the negatives one by one, no batch conversions. Sometimes this happens: I set the white balance from the rebate, click to convert, and it crashes. I then revert the image to the Lightroom import stage, do not set white balance, convert, and it converts the negative without an issue. This behavior is random as well: this will work on some negatives but not others.
Yeah, the same happens to me. It’s now random but effectively keeps me from using roll scan. Very disappointing, as this error keeps the software from being convenient.
As noted above, I’ve downgraded Lightroom Classic to version 13.4. No more issues (on macOS 14.7.1 on 5K iMac 2019) since then, no matter how many images I converted.
In my latest (limited) tests on M1 MacBook Air 2020, I had no issues with Lr 14.0.1 macOS 15.1.
In both cases, I tested with the official NLP 3.0.2 release.
I mostly converted from Library/Grid view.
No real issues in the past but since upgrading to Sequoia and LRC 14 NLP conversion crashes every time. However I can limp through a roll doing up five frames at a time.
Same problem with LRC 13.5 and LRC 14. Using Intel MBP. I downgraded to 13.4 which seems to solve the problem. A shame that I lost all changes from a few months with v13.5 catalog as it is not compatible with older versions.
