Edits not saving when switching between images in NLP v3.1.1
Hi, I’m experiencing an issue with Negative Lab Pro v3.1.1.
When I open multiple images in the plugin and make corrections, then move between them using the arrow keys, the changes are not saved after I close the plugin. I’ve tested different workflows (single image, batch, sync settings) and the problem persists.
My setup:
- Lightroom Classic version 15.0
- macOS 15.7.1
- Negative Lab Pro version: 3.1.1
- Camera canon R5
- File type: RAW-CR3
Steps to reproduce:
1. Select multiple converted negatives.
2. Open NLP.
3. Adjust first image → move with arrow key → adjust next image.
4. Click “Apply” and close NLP.
5. Reopen images → changes not saved.
Is this a known issue or is there a fix/workaround?
Thanks a lot!
Sandro
Welcome to the forum @sandro
What do you mean by “Reopen images → changes not saved”?
  • Open images with NLP?
  • The sliders aren’t where you left them?
  • The image falls back to the look it had before you adjusted the image?
Do you have any other LR plugins installed? I had similar issue when i was using Tourbox device for edits in LR. I had to disable Tourbox software and that solved the issue.
