I try to use NLP for conversions of a so called DT files from the Creo scanner
These should be linear Tiffs. However, every time when i use Tiffprep utility it ends with an error!
Meanwhile file is prepared, but annoying message appears on every processed file
Please find below a link to the linear DT file
A link to the ICC profile indended to viewing DT files correctly in photoshop
contains exact gamma transformation
I believe the issue here is the use of restricted characters within the file path name. Here, it looks like you have a folder named “#CSAN”. Having the hashtag (or any uncommon character) in the folder name will cause issues with exiftool (the program that is updating the metadata).
