After converting negatives with NLP v2.3 in Lightroom Classic V11.1, each converted negative displays an exclamation mark in the upper right corner. When I click on it, the message “There was an unknown error while writing metadata to this photo. Retry” My options are: “Retry Metadata export” or “Import Settings from Disk”. I chose the “Retry” option, which seems to take care of the issue. But, this is time consuming because I have to do this for every negative converted y NLP. This began after I upgraded to NLP 2.3.
Do you have any recommendations to correct this issue?
Thank you,
Steve
