I’ve tried everything; I can’t get a decent conversion, every color looks odd, and there’s a lot of digital noise. This is not happening at all with the Silverfast conversion.
My workflow is to run the Silverfast prep tool from File, then I read the metadata, then auto wb because the Plustek scanner doesn’t leave a border to sample from, and then I click on convert negatives.
This is the result with multiples roll scanned.
Also after doing couple of tries my files are like half the size and lost details and now i’m pretty sure i’ve to rescan all the pictures…
Don’t do auto WB. Try to convert without setting the WB. That works for me. Also, you can try to move the negatives a little bit in the holder when you are scanning. Scan one frame with a little bit of unexposed film. Set there the WB in Lightroom and copy the settings to the other photos of the roll
I will load it in a few hours when I’ll back from work. Most likely they do not have borders or only a little bit, the scanner I’m using is a Plustek 8300i.
Compare to how I scan, I never seen such a dark border before. And then after I convert your files I see so much noise that I can’t help but think that the scanner is underexposing. This is just speculation from observation of the files you shared.
Do you have Vuescan? As far as a I remember one can customize a lot in that software, not sure if you can push the scanner to overexpose in SF.
These negatives very much look like they’re broken. I pushed expose pre-NLP-conversion and the results look “somewhat” better already. But definitely there’s information missing in the negs, likely from a lack of light during the scan process.
I’m not familiar with Silverfast, but should be fixable given SF can convert the photos.
