LR 14.5 / german / Win11 / NLP 3.1.1: Hotkey launches "plugin manager" panel instead of NPL
Configuration:
Win 11 / language setting: German
LR Classic 14.5 / language setting: German
NPL 3.1.1
After updating LR to 14.5 a few days ago, I notoced that using the (German language) hotkey (cntl alt p) does not launch NPL anymore, but the LR plugin manager panel instead.
Switching the LR languange to English, and using the proper English hotkey (cntl alt n) works ok and launches NPL as it should.
According to the NegativeLabHotkey.ahk file which I downloaded, the standard German hotkey (cntl alt p) sends the following keystrokes to LR: Alt down-d-Alt up-z-N.
When I enter this same keystroke sequence manually, the LR plugin manager panel gets shown - so it seems to me that NegativeLabHotKey.exe is doing what it was programmed to do, but that the sequence of keystrokes required to launch NLP on LR classic / german has changed with 14.5: now it is Alt down-d-Alt up-u-u-Cursor right-N which launches NPL (at least it does so on my Win PC!).
My current workaround is switching the Lightroom language to English and using the English language hotkey. Alternatively I guess I could use AutoHotKey with a modified ahk-file.
Hallo alle,
Win 11/ Spracheinstellung: Deutsch
LR Classic 14.5 / Spracheinstellung: Deutsch
NLP 3.1.1
Mit dem LR Update 14.5 hat Adobe in der deutschen Version für den den colorpicker des Color Mixer den Shortcut “Strg+Alt+p” eingeführt. Dieser Shortcup funktioniert natürlich nur, wenn die NegativeLabHotkey.exe nicht gestartet ist. Wenn gestartet öffnet der Hotkey den Plug-in Manager.
Ich bin kein Programmierer, habe davon keine Ahnung. Deshalb wäre ich glücklich, wenn die NLHotkey.exe für alle verfügbar geändert wird und dann zum Download bereitgestellt wird!
With LR Update 14.5, Adobe introduced the shortcut “Ctrl+Alt+p” for the colorpicker in the Color Mixer in the German version. Of course, this shortcut only works if NegativeLabHotkey.exe is not running. If it is running, the hotkey opens the Plug-in Manager.
I am not a programmer and have no idea about this. Therefore, I would be happy if NLHotkey.exe were modified to be available to everyone and then made available for download!
Hi @Ralph
Ok, let me look into this. In the meantime, there is already a way for you to download a script you can customize to find a hotkey that works in your environment and setup in the Windows Installation Guide
Here’s how to do it from that page:
If you’d like to change the hotkey (or add to an existing AutoHotKey setup), you can download the hotkey script here. Even if you are new to AutoHotKey, it is possible to customize the script to meet your needs.
  1. Download and install AutoHotKey free from https://www.autohotkey.com/
  2. Right-click on the “NegativeLabHotkey.ahk” file, and choose to open with NotePad
  3. Inside the ahk file are further instructions for how to edit to meet your needs
that was hard work! Finaly, I got it though. The main problem was to realize that the key combination “Alt down d alt up u enter n” always opened “import from another catalog”. That was because of in the german menu “Datei” (file) you must press Alt+d to open. Then press “u” twice to get to the plug-in extras.
Finaly I could manage it by using:
; German / Deutsch
#IfWinActive Adobe.*Lightroom.*Entwickeln || Adobe.*Lightroom.*Bibliothek
#b::
Send, {Alt down}d{Alt up}uu{Enter}N
Return
After this pain in the ass, I am fine now!
Thx!
You may want to change this in the NegativeLabHotkey so that it is available to everyone.
Best regards from Germany
Ralph
+49 1520 2945645
Same Problem here. Took me hours to find the problem, the correct blog post and fix that issue. Please fix that from your side!
Otherwise. Great product guys! :slight_smile:
Update as of Lightroom Classic version 15 - again in the German language. This is a version of the hotkey script that’s working for me:
; German/Deutsch
^!N::
   Send, {Alt down}dtN{Enter]
Return
The hotkey is Ctrl+Alt+N because, as @Ralph mentioned, Ctrl+Alt+P now opens the plug-in manager.
The keys triggered by AutoHotKey are
  • {Alt down}d - to open the “Datei” ("File”) menu
  • t - to select the menu item “Plug-in-Extras”
  • N{Enter] - to open “NegativeLabPro”
I have the same problem that began this week. My language is spanish. Not resolved by trying different tab combinations.
Win 11/ Spanish
LR Classic 15.1 (the last one)
NLP 3.1.1
Furthermore, I’m not able to customize any script at all.
Please fix this very ennoying issue.
Thanks
The issue has been resolved with the latest version of LrC (15.1.1)
Hi there, unfortunately this didn’t fix it for me. I still have this problem with the german version.
Im running the newest versions, Lightroom 15.3 and NLP 3.1.1
Updating or changing the hotkey like suggested above didn’t help.
The Lightroom Plugin Manager opens, or other functions of Lightroom.
I need a foolproof way, i tried things with autohotkey but i can’t make that work either. im going insane :frowning:
